GSM module to 8051 microcontroller
Hassan Gazal
Junior Member level 3
Dear , All
I need to connect Microcontroller 8051 with GSM modem, and send AT commands through 8051.
I did it before , but using a very expensive GSM modem .
so if there is any way to build a small Circuit GSM modem.
it will be difficult to do that....
i think price of GSM module is Rs1500....
according to me it will be efficient to use GSM module....
sim300 module also works fine through UART OF 8051..
Thanks for you all
im in egypt but i can not find it here , so if any website to buy it and chip to egypt , i need a cheap one.
Thanks bigdogguru
can you please check this one and tell me if it's suitable to interface it with 8051 and send AT commands .
can you please check also this one it's cheap than the other one , if it is also suitable for me
https://www.sainsmart.com/siemens-tc35-sms-gsm-module-voice-adapter.html
sorry , these modules can send sms for long distance , i mean our mobiles using GSM and you can send a sms to your friend in another city or another country , so these ,modules can do it ???
Yes, both modules appear to be the same, capable of SMS and voice transmission and offer either UART TTL or RS-232 connections.
And the second link appears to be considerably less expensive.
It also has several downloadable files, including a few Arduino test sketches:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
An Arduino Leonardo
a GSM card Siemens TC 35
A transformer block 5v DC
Connections: It is necessary to connect the ground (GND) of the TC35 card to the mass of the Arduino (yellow wire).
Then connect the TX port of the TC35 (green wire) to a digital port of the Arduino (here the port 9) card and connect the RX port of the TC35 (blue wire) to the digital port (here 10) map Arduino.
ATTENTION: the Leonardo card for RX harbor only pins 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI) can be used. The power of the TC35 should be 5v DC, positive focus. It is necessary to turn on the TC35 card by pressing the left button of the RS232 port, the red LED will flash slowly if everything is ok (valid SIM card)
SMS sending Test:
Note: The flow rate should be between 9600 Arduino and TC35, AT commands typed without space. The following program allows you to enter a message in the serial monitor then sends.
#include <SoftwareSerial.h>
 #define rxPin 10
 #define txPin 9
 // set up a new serial port for Leonardo
 SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
 char recu[150];   // Array for entering message
 String message="";  //string we're sending
 int i;
 void setup()
 {//--For Leonardo
  Serial.begin(9600);
  while (!Serial){
 // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
   delay(5000);
   Serial.println("Hello, tapez votre SMS en terminant par un point");
 void loop()
    i = 0 ;
    while ( Serial.available()>0 )
    {recu[i] = Serial.read();
     message += recu[i];
     i++;
     //-- 46 is the Ascii code for "."
     if (recu[i-1]==46)
     Serial.println("Envoi du SMS...");
     SendTextMessage();
     ShowSerialData();
     delay(1000);
     Serial.println("\r"); //-- Carriage return
     Serial.println("SMS parti !");
     message="";
     i=0;
 ///SendTextMessage()
 ///this function is to send a sms message
 void SendTextMessage()
 { mySerial.print("AT+CMGF=1\r");  //Because we want to send the SMS in text mode
  delay(1000);
  mySerial.print("AT+CMGS=\"+336xxxxxxxx\"\r");
  delay(1000);
  mySerial.println(message);
  mySerial.print("\r");
  delay(1000);
  mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
  mySerial.println();
 void ShowSerialData()
  while(mySerial.available()!=0)
   Serial.write(mySerial.read());
Be careful to read the information from the card, it is necessary to change the size of the receive buffer in file SoftwareSerial.h line # define _SS_MAX_RX_BUFF 1024 / / RX buffer size (here we increased the buffer to 1k).
Example of sending commands to the card and read the result.
 SoftwareSerial mySerial(10, 9);
 int i;
 String message="";
 void setup()
 {//--For Leonardo
  Serial.begin(9600);
  while (!Serial){
  delay(5000);
  Serial.println("Started!");
  Serial.println("Hello, tapez votre commande en terminant par un point");
  //-- Choose SIM memory and show the SMS in MEMORY
  //-> AT+CPMS="SM". //mySerial.println( "AT+CPMS=\"SM\"" );
  //-- Ask for all the SMS
  //-> AT+CMGL="ALL".// mySerial.println( "AT+CMGL=\"ALL\"" );
  //-> AT+CMGR=2. // Read the 2nd message
  //-> AT+CMGD=2. // Delete the 2nd message
  //-> AT+CNMI=?. //-- Test received message
 void loop()
   i = 0 ;
     if ((recu[i]!=46)&&(recu[i]!=13)&&(recu[i]!=10))
       message += char(recu[i]);
     i++;
     if (recu[i-1]==46)
     Serial.println("Envoi de la commande ["+message+"]");
     SendCmdMessage();
     ShowSerialData();
     Serial.println("Commande finie,tapez votre commande en terminant par un point");
     message="";
     i=0;
   Serial.print(char(mySerial.read()));
 void SendCmdMessage()
 { mySerial.println(message);
  delay(1000);
Lighting a LED upon receiving an SMS and erase the SMS:
 int i;
 int dp=0;
 char c;
 String message="";
 String cmd="";
 String cReturn="";
 int nReturn=0;
 int nPremier=0;
 //--Pin of the LED to turn ON and OFF
 int ledPin = 5;
 void setup()
 {//--For Leonardo
  Serial.begin(9600);
  while (!Serial){
  delay(5000);
  Serial.println("Hello, Pour commencer taper Envoyer");
  message="AT+CPMS=\"SM\"";
     SendCmdMessage();
     ShowSerialData();
     Serial.println(nReturn);
     nPremier=nReturn;
      pinMode( ledPin, OUTPUT );
  digitalWrite( ledPin, LOW);
 void loop()
    { message="AT+CPMS=\"SM\"";
     SendCmdMessage();
     ShowSerialData();
     Serial.print("Nombre de SMS : ");
     Serial.println(char(nReturn+48));
     if (nReturn>nPremier)
       {Serial.println("Nouveau SMS !");
        //nPremier=nReturn-1;
        Serial.print(nReturn);
        Serial.print(" ");
        Serial.println(nPremier);
        digitalWrite( ledPin, HIGH);
        delay(1000);
        //--Read the nReturn message
        message="";
        message=nReturn+message;
        message="AT+CMGR="+message;
        SendCmdMessage();
        ShowSmsData();
        delay(1000);
        //--Delete the nReturn message
        message="";
        message="AT+CMGD="+message;
        SendCmdMessage();
        ShowSmsData();
        message="";
       delay(1000);
 { cReturn="";
   //Serial.print(char(mySerial.read()));
   c=char(mySerial.read());
   switch(dp){
   case 1 :
       if (c==44)///-- Acii code for Comma
          dp=2;
       else
          cmd+=c;
       break;
   case 2 :
       if (cmd!="")
        { cmd.trim();
         //Serial.println("Mem SMS ["+cmd+"]");
         cReturn=cmd;
         if (cReturn.length()==1)
           {c=cReturn.charAt(0);
           nReturn=c-0;
           nReturn=nReturn-48;}
          else
           nReturn=0;
       dp=0;
       cmd="";
       break;
   default :
       if (c==58) //-- Acii code for :
        dp=1;
       break;
 void ShowSmsData()
   switch(dp){
   case 1 :
       if (c==13)///-- Acii code for Return
          dp=2;
       else
          cmd+=c;
       break;
   case 2 :
       if (cmd!="")
       dp=0;
       cmd="";
       break;
   default :
        dp=1;
       break;
  delay(1000);
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
  // Delete all SMS in SIM Memory then :
  // Wait for SMS, if SMS=OK Light PIN 5
  // if SMS=OFF light off PIN 5
  // if SMS=? give a status (ON or OFF) of PIN 5
  // Otherwise return to the SMS sender a message
  // If the AT command as an error light PIN 3
  // If the AT command is ok light PIN 4
  int dp=0;
  int i=0;
  int dpLed=0;
  char c;
  String message="";
  String Res="";
  String TxtSms="";
  String NumSms="";
  String cReturn="";
  int nReturn=0;
  int nPremier=0;
  //--Pin of the LEDs
  int ledPinRel = 5; //-- Led Action Or Relay
  int ledPinOk = 4; //-- Led OK
  int ledPinErr = 3; //-- Led Error
  void setup()
  delay(5000);
  //-- SMS in text mode
  message="AT+CMGF=1";
  SendCmdMessage();
  ShowSerialData();
  //-- Print storage status
  SendCmdMessage();
  ExtractSmsNumber();
  //--Delete all the SMS
  for (i=nReturn; i>0; i--)
    { message="";
     message=i+message;
     SendCmdMessage();
     ShowSerialData();
  SendCmdMessage();
  ExtractSmsNumber();
  nPremier=nReturn;
  //-- Initialize LED PIN
  pinMode( ledPinRel, OUTPUT );
  digitalWrite( ledPinRel, LOW);
  pinMode( ledPinErr, OUTPUT );
  digitalWrite( ledPinErr, LOW);
  pinMode( ledPinOk, OUTPUT );
  digitalWrite( ledPinOk, HIGH);
  void loop()
   SendCmdMessage();
   ExtractSmsNumber();
   dp=0;
     {//--Read the nReturn message
     message="";
     SendCmdMessage();
     ShowSmsData();
     if (TxtSms=="ON")
       dp=1;
     if (TxtSms=="OFF")
       dp=2;
     if (TxtSms=="?")
       dp=3;
     switch (dp) {
      case 1 :
          {digitalWrite( ledPinRel, HIGH);
          dpLed=1;
          break;}
      case 2 :
          {digitalWrite( ledPinRel, LOW);
          dpLed=0;
          break;}
      case 3 :
          {if (dpLed==1)
             message="La LED est ON";
             else
             message="La LED est OFF";
           SendSms();
           message="AT+CMGD=1";
           SendCmdMessage();
           ShowSerialData();
           break;
       default :
         {message="Erreur, tapez ON, OFF ou ?, merci !";
          SendSms();
          SendCmdMessage();
          ShowSerialData();
          break;}
     message="";
     SendCmdMessage();
     ShowSerialData();
     delay(1000);
  void ExtractSmsNumber()
  {cReturn="";
  Res="";
  nReturn=1;
  dp=0;
   //if ((c!=13) && (c!=10))
   //  Res+=c;
   switch(dp){
   case 1 :
      dp=2;
     else
      Res+=c;
     break;
   case 2 :
     if (Res!="")
     { Res.trim();
      cReturn=Res;
       nReturn=c-0;
      else
       nReturn=0;
     dp=0;
     Res="";
     break;
   default :
     dp=1;
     break;
  Res.toUpperCase();
  if (Res.indexOf("OK")>0)
      {digitalWrite( ledPinOk, HIGH);
  if (Res.indexOf("ERROR")>0)
      {digitalWrite( ledPinOk, LOW);
       digitalWrite( ledPinErr, HIGH);
 void ShowSmsData()
 //-- Read the sender number (NumSms) and the text message (TxtSms)
 //-- The return code format is : [+CMGR: "REC READ","+336xxxxxxxx",,"13/06/10,22:18:35+08"<CR><LF>Message<CR>]
 {dp=0;
  TxtSms="";
  NumSms="";
  Res="";
    Res+=c;
   if ((c==44) && (dp==0))///-- 44 Ascii code for ','
    {//-- Entering Phone Number
     c=char(mySerial.read()); //-- Reading '"'
     dp=1;}
   if ((c==34) && (dp==1))///-- 34 Ascii code for '"'
    {//-- Leaving Phone Number
     dp=2;}
   if ((c==13) && (dp==2))///-- 13 Ascii code for <CR>
    {//-- Entering Message zone
     c=char(mySerial.read()); //-- Reading <LF>
     dp=3;}
   if ((c==13) && (dp==3))///-- 13 Ascii code for <CR>
    {//-- Leaving Message zone
     dp=4;}
   switch(dp){
   case 1 :
       NumSms+=c;
       break;
   case 3 :
       TxtSms+=c;
       break;
 TxtSms.toUpperCase();
 TxtSms.trim();
 Res.toUpperCase();
 void SendSms()
  mySerial.println("AT+CMGS="+NumSms);
  delay(1000);
  delay(1000);
  delay(1000);
  ShowSerialData();
  delay(1000);
  delay(1000);
  {Res="";
  {c=char(mySerial.read());
    Res+=c;
   Res.toUpperCase();
BigDog
just one thing , i have already find the target GSM module on Ebay , and i live in Egypt
My friend told me that they will not permit this module to pass in Customs at the airport , so is it right ??
that's mean if i pay to ebay i will not receive the module :(
