PIC uC digital clock.
imranahmed
Advanced Member level 3
Karachi,Pakistan
Please let me know that I`m going to build digital clock by using 7-segment display.
Please can anyone refer me any link or C-code tricks by using PIC uC.
You can see this project link :
A Real Time Clock IC (DS1307) project using the PIC micro
https://www.best-microcontroller-projects.com/real-time-clock-ic.html
Source is written in MikroC.
Your given circuit is great but I want to make digital clock by only using uC (PIC or AT89C52).
Please refer any link or hint.
This change thing, you say in post #3 - 89C52.
Go to this link (registration is free), MikroC source code, Tutorial:
Simple Digital clock using 8051 microcontroller (AT89C51)
Please check my code and circuit.
Question is that I want to make digital clock 4-digits for Hours and Minutes.The minutes digit increase after every 60 secs and hour digits increase after every 60 mins but problem is that if i add delay() function for 1 sec the display off and on and cannot display without flickering how to avoid this problem.
Please run my circuit.
Tahmid please read my code and circuit and please find any hint for solving problem.
  • DClock.txt
...... but problem is that if i add delay() function for 1 sec the display off and on and cannot display without flickering how to avoid this problem.
Adding delay of 1 sec will definatly flicker your display. Dont add delay() function, instead use timer interrupt function for updation of sec. OR you can add 1 ms delay () function and update a variable of millisecond variable, and when millisecond is equal to 1000 increase the sec variable and so on.
In uC 89c52 there are 2 timer interrupt 1)interrpt 0 and interrupt 3.
My question is that can we use interrupt 1 or 3 two,three,four times and so on OR use interrupt only for one task.?
You can use interrupt for more task, its all depends on programing style and requirment.
Means if I used interrupt 3 (its timer interrupt) for any task then I can use same interrupt 3 for another task in same program.
