step down transformer help
power--man
Junior Member level 1
hi guys
i need sum help:)
does anyone know if i can get a stepdown down transformer to drop 230Vac(mains) to 12Vac ? and is it expensive
thanks
230V - 12V transformers are easily available in the market. What is the power rating which you are looking at...the price depends on the power rating...
thank you devura i will look in2 it
---------- Post added at 13:24 ---------- Previous post was at 13:11 ----------
im designing a voltage sensor by stepping down the mains voltage to 12Vac , then bringing that voltage down with the use of resistors to 660mv to run a mcp3909, what power rated transformer do u suggest i use?
thank you for all your help
Can You give us whole and complete ilustration of problem and final goal ?
Are you plan to make 3-phase energy meter circuit ?
There is tons and tons trafo 220V/110V to 12V, if you cant find just search trafo for halogen light (12V).
hi tpetar
Its a single phase energy meter, to sense voltage and current and then send that data to the mcp3909
I think, a 5VA Transformer should do for your application...
This is goal ? You need 9V DC for that.
MCP3909 and PIC18F85J90 Single Phase Energy Meter
  • 51884a.pdf
thanks for the reply
the mcp3909 requires a maximum AC input of 660mv , why would I need a 9V DC ? , im stepping down mains 230V ac to 12V ac , then using resistors to drop it down to 660mv ac into the mcp3909, will it work?
thanks
You didnt answer on question in my post #7.
I think You mix current transformer with standard. You didnt make Your question nicely :
MCP3909 have :
Vdd 7V
Digital inputs and outputs w.r.t. AGND....... -0.6V to VDD +0.6V
Analog input w.r.t. AGND..................................... ....-6V to +6V
VREF input w.r.t. AGND.............................. -0.6V to VDD +0.6V
  • MCP3909.pdf
