issue with with WIFI 5G 160M Bandwidth throughput test with iperf.
arr_baobao
Full Member level 2
Hi all,
i'm testing my device WIFI 5G 160m bandwidth throughput test with iperf.
I'm using Asus axe11000 router and test was conducted in a sheilded room.
below capture is my test result. the top one the is downlink performance which is ok.
but the btm one the uplink is very bad.
with the same setup i use another test software ixchariot to check the throughtpput performance and i dont see issue in uplink.
anyone know what the reason why im getting vry bad throughtput with iperf test? any setting need to be done?
thanks.
