Mahendra_mrs
Newbie level 1
- Joined
- Jan 13, 2015
- Messages
- 0
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 0
- Location
- Surat, Gujarat, India
- Activity points
- 0
hello freaks,
I'm newbie at this forum and this on one my first post, from couple of days I'm dealing with DHT 22 sensor to interfacing with avr, my application is to measure humidity and temperature from DHT 22 and send those data to PC using UART.
Before that I've studied DHT 22 sensor datasheet and it's one wire interface and got some idea from internet to interface DHT 22 and developed code in c
but the problem is sensor not responding to avr and i just getting error msg on serial terminal(as if checksum will not happy, then it will display 'error' msg at serial terminal )
here is my complete code
//**********************************************dht.h*******************************************************
#ifndef DHT_H_
#define DHT_H_
#include<stdio.h>
#include<avr/io.h>
//setup port
#define DHT_DDR DDRD
#define DHT_PORT PORTD
#define DHT_PIN PIND
#define DHT_INPUTPIN PD6
//sensor type
#define DHT_DHT11 1
#define DHT_DHT22 2
#define DHT_TYPE DHT_DHT22
//enable decimal precision (float)
#if DHT_TYPE == DHT_DHT11
#define DHT_FLOAT 0
#elif DHT_TYPE == DHT_DHT22
#define DHT_FLOAT 1
#endif
//timeout retries
#define DHT_TIMEOUT 200
//functions
#if DHT_FLOAT == 1
extern int8_t dht_gettemperature(float *temperature);
extern int8_t dht_gethumidity(float *humidity);
extern int8_t dht_gettemperaturehumidity(float *temperature, float *humidity);
#elif DHT_FLOAT == 0
extern int8_t dht_gettemperature(int8_t *temperature);
extern int8_t dht_gethumidity(int8_t *humidity);
extern int8_t dht_gettemperaturehumidity(int8_t *temperature, int8_t *humidity);
#endif
#endif
//*****************************************main.c***************************************
#include<stdio.h>
#include<stdlib.h>
#include<avr/io.h>
#include<avr/interrupt.h>
#include<util/delay.h>
#define F_CPU 16000000ul
#include "dht.h"
void UART_init();
void uart_puts(char*str);
void uart_putch(unsigned char data);
int main(void)
char printbuff[100];
UART_init();
#if DHT_FLOAT == 0
int8_t temperature = 0;
int8_t humidity = 0;
#elif DHT_FLOAT == 1
float temperature = 0;
float humidity = 0;
#endif
uart_puts("DHT _22 test \r\n");
_delay_ms(2000);
for (; {
if(dht_gettemperaturehumidity(&temperature, &humidity) != -1) {
#if DHT_FLOAT == 0
itoa(temperature, printbuff, 10);
dtostrf(temperature, 3, 3, printbuff);
#endif
uart_puts("temperature: "); uart_puts(printbuff); uart_puts("C");uart_puts("\r\n");
#if DHT_FLOAT == 0
itoa(humidity, printbuff, 10);
dtostrf(humidity, 3, 3, printbuff);
#endif
uart_puts("humidity: "); uart_puts(printbuff); uart_puts("%RH");uart_puts("\r\n");
} else {
uart_puts("error"); uart_puts("\r\n");
uart_puts("\r\n");
_delay_ms(1500);
return 0;
void UART_init()
UCSRB= (1<<RXEN)|(1<<TXEN); // Enable Receiver and Transmitter
UCSRC= 0x86; // Asynchronous mode 8-bit data and 1-stop bit
UCSRA= 0x00; // Normal Baud rate(no doubling), Single processor commn
UBRRH= 0x19;
UBRRL= 0X0F; // 2400 Baud rate at 16 MhZMHz
while((UCSRA &(1<<UDRE))==0);
UDR=data;
void uart_puts(char *str)
while(*str!='\0')
uart_putch(*str);
str++;
//***********************************DHT.c***************************
DHT Library 0x03
copyright (c) Davide Gironi, 2012
Released under GPLv3.
Please refer to LICENSE file for licensing information.
#include <stdio.h>
#include <string.h>
#include <avr/io.h>
#include <util/delay.h>
#include "dht.h"
* get data from sensor
#if DHT_FLOAT == 1
int8_t dht_getdata(float *temperature, float *humidity) {
int8_t dht_getdata(int8_t *temperature, int8_t *humidity) {
#endif
uint8_t bits[5];
uint8_t i,j = 0;
memset(bits, 0, sizeof(bits));
//reset port
DHT_DDR |= (1<<DHT_INPUTPIN); //output
DHT_PORT |= (1<<DHT_INPUTPIN); //high
_delay_ms(100);
//send request
DHT_PORT &= ~(1<<DHT_INPUTPIN); //low
_delay_ms(18);
_delay_us(500);
#endif
DHT_DDR &= ~(1<<DHT_INPUTPIN); //input
_delay_us(40);
//check start condition 1
if((DHT_PIN & (1<<DHT_INPUTPIN))) {
return -1;
_delay_us(80);
//check start condition 2
if(!(DHT_PIN & (1<<DHT_INPUTPIN))) {
return -1;
_delay_us(80);
//read the data
uint16_t timeoutcounter = 0;
for (j=0; j<5; j++) { //read 5 byte
uint8_t result=0;
for(i=0; i<8; i++) {//read every bit
timeoutcounter = 0;
while(!(DHT_PIN & (1<<DHT_INPUTPIN))) { //wait for an high input (non blocking)
timeoutcounter++;
if(timeoutcounter > DHT_TIMEOUT) {
return -1; //timeout
_delay_us(30);
if(DHT_PIN & (1<<DHT_INPUTPIN)) //if input is high after 30 us, get result
result |= (1<<(7-i));
timeoutcounter = 0;
while(DHT_PIN & (1<<DHT_INPUTPIN)) { //wait until input get low (non blocking)
timeoutcounter++;
bits[j] = result;
//reset port
DHT_PORT |= (1<<DHT_INPUTPIN); //low
_delay_ms(100);
//check checksum
if ((uint8_t)(bits[0] + bits[1] + bits[2] + bits[3]) == bits[4]) {
//return temperature and humidity
*temperature = bits[2];
*humidity = bits[0];
uint16_t rawhumidity = bits[0]<<8 | bits[1];
uint16_t rawtemperature = bits[2]<<8 | bits[3];
if(rawtemperature & 0x8000) {
*temperature = (float)((rawtemperature & 0x7FFF) / 10.0) * -1.0;
} else {
*temperature = (float)(rawtemperature)/10.0;
*humidity = (float)(rawhumidity)/10.0;
#endif
return 0;
return -1;
* get temperature
#if DHT_FLOAT == 1
int8_t dht_gettemperature(float *temperature) {
float humidity = 0;
int8_t dht_gettemperature(int8_t *temperature) {
#endif
return dht_getdata(temperature, &humidity);
* get humidity
#if DHT_FLOAT == 1
int8_t dht_gethumidity(float *humidity) {
int8_t dht_gethumidity(int8_t *humidity) {
#endif
return dht_getdata(&temperature, humidity);
* get temperature and humidity
#if DHT_FLOAT == 1
int8_t dht_gettemperaturehumidity(float *temperature, float *humidity) {
int8_t dht_gettemperaturehumidity(int8_t *temperature, int8_t *humidity) {
#endif
return dht_getdata(temperature, humidity);
can anyone help me to solve this trouble?:roll:
#ifndef DHT_H_
#define DHT_H_
#include<stdio.h>
#include<avr/io.h>
//setup port
//sensor type
#define DHT_DHT11 1
#define DHT_DHT22 2
#define DHT_FLOAT 0
#define DHT_FLOAT 1
#endif
//timeout retries
//functions
#if DHT_FLOAT == 1
#endif
#endif
#include<stdio.h>
#include<stdlib.h>
#include<avr/io.h>
#include "dht.h"
void UART_init();
int main(void)
UART_init();
#if DHT_FLOAT == 0
float humidity = 0;
#endif
_delay_ms(2000);
for (; {
#if DHT_FLOAT == 0
#endif
#if DHT_FLOAT == 0
#endif
} else {
uart_puts("\r\n");
_delay_ms(1500);
return 0;
void UART_init()
UBRRH= 0x19;
UDR=data;
while(*str!='\0')
uart_putch(*str);
str++;
DHT Library 0x03
#include <stdio.h>
#include <string.h>
#include <avr/io.h>
#include "dht.h"
#if DHT_FLOAT == 1
#endif
uint8_t bits[5];
uint8_t i,j = 0;
//reset port
_delay_ms(100);
//send request
_delay_ms(18);
_delay_us(500);
#endif
_delay_us(40);
return -1;
_delay_us(80);
return -1;
_delay_us(80);
//read the data
uint8_t result=0;
timeoutcounter = 0;
timeoutcounter++;
_delay_us(30);
timeoutcounter = 0;
timeoutcounter++;
bits[j] = result;
//reset port
_delay_ms(100);
//check checksum
} else {
#endif
return 0;
return -1;
* get temperature
#if DHT_FLOAT == 1
float humidity = 0;
#endif
* get humidity
#if DHT_FLOAT == 1
#endif
#if DHT_FLOAT == 1
#endif
