Register Log in
Zilog comparator programming for battery and supercap
kct
Newbie level 1
Good day to everyone.
Currently I'm in the process of using a Zilog MCU (Z8F042A) to design a voltage comparator for comparing a voltage between a mobile phone battery with a maximum voltage of 4.2V, and a supercapacitor(s) rated at 5V. At any instant the supercapacitor's voltage is equivalent to that of the battery, the system will send a voltage to the gate of a P channel MOSFET to switch the MOSFET off. The moment the supercapacitor's voltage falls below that of the battery, the MOSFET is to be switched on again.
The problem now is, I am not so sure about programming the Zilog itself (programming has never been my strong point), not to mention the issue of whether I need to use the ADC or not. It would be great if anyone can help me out.
#include<eZ8.h>
#include <stdio.h>
#include <sio.h>
#include <adc.h>
unsigned int VINSUP; // Voltage from Supercapacitor
unsigned int VINREF; // Voltage from Battery
void main(void)
	ADCCTL0 = 0xAE; // Conversion Enabled
					// Reference Buffer Disabled
					// Continuous Mode
	ADCCTL1 = 0x01; //Single Ended Buffered Input with Unity Gain
	PCDD = 0xF7; // PC3 as output and others as input
	PCOUT = 0xFF; // Turn off all ports
	while(1)
		if ((PCIN & 0x01) == 0) // To check if PC0 is low or not
			PCOUT = 0xF7;
		else
			PCOUT = 0xFF;
Toggle Sidebar
