I need to know which is the best language to write a Zigbee Programming and how do i link the program with my zigbee? i have done "talking" with my XBee Pro 900 Wire Antenna (sku: WRL-09097) using X-CTU.
According to the product page, the XBee Pro 900 are shipped with the DP multipoint proprietary firmware which should provide out-of-the-box communications, no setup required.
What type of breakout board are you using in conjunction with X-CTU to provide a serial interface?
Can use AT command. Actually, for first time use, no need to set. You can use default setting to interfacing with UART 9600 baudrate.
See this XBee Lesson.
