In my project wireless (zigbee) have to use but i don't know how to generate ZigBee using
Microcontroller, Want following details,
1. Which microcontroller should support "Zigbee".
2. What are the pins needed to generate ZigBee signal,
3. at same time i have to use TFT display in that controller,
Are you want to make Zigbee by own?
Why you dont use the readymade Zigbee boards?
They are easy to use and have an interface like SPI or Serial for interfacing it with microcontroller's.
Almost every microcontroller support readymade zigbeed boards
The majority of ZigBee modules have an asynchronous serial port and a few have a SPI interface. The ZigBee modules with have the asynchronous serial port require only an UART on the MCU. They also use a standard AT command set, therefore no special libraries are required.
The ZigBee modules with SPI port usually require the use of a ZigBee library to implement the ZigBee network. And the library maybe platform specific and requiring the use of a particular family of MCUs.
As bigdogguru gives you the link you can use these kinds of Zigbee's with your microcontroller.
As making Zigbee by own is not as easy because you have to consider lot of things like its antenna lenght,tracks for the pcb's etc.
To transfer the data from micro-controller to system(Computer) using Zigbee tech for wireless and RS232 for interface b/w system and zigbee at receiver section.
