josrodmar
Newbie level 2
Hi, I've been trying to build a simple zero crossing detector with an LM741 opamp with no much success. This zero crossing must work with a period sine wave of 60hz and provide an output of 5V when the wave is positive and 0V when the wave negative. The problem is the signal that I'm going to measure has an amplitude as little as 1mV. I figured out that if I connect this signal to the positive pin of the comparator and a ground to the negative pin, it won't work in single power supply configuration. I'm planning on raising this signal to an offset and compare the signal input with the offset. do you guys have any suggestion, or design available for signals that are as low as 1mV for 60hz periods.
