umery2k75
Advanced Member level 1
Hello everyone,
To understand transimpedance amplifiers in more detail. I reverse engineered an electronic card of a photodiode amplifier of a machine which was not working because machine was scrap and probably made in around 1992 and It had few cards in it and few cards were lost and fortunately the photodiode card was present, so I took out the card and drew the schematic.
I removed all the components, so that I make no mistakes in drawing schematic. You can see.
To this CAD version...
The reason I showed above pictures is to show my determination and whatever circuit I presents on EDABoard platform contains no error and no mistake. It is exactly the same schematic drawn from actual PCB.
The schematic of the circuit is like this. The lights falls on D1-D4 in forms of shadows and light, so the output must creates a modulating sine wave output. The higher the amplitidue of the sine wave - the higher the amplitude modulation.
Note:
Note:
- I didn't measure the value of C31 and C33. I will measure it later, because it was not necessary at that moment. First to understand the schematic was important.
- This transimpedance amplifier seems like a zero bias to me, because +5V is appeared to be present at both Anode and Cathodes of the photodiode. How? I think because applying +5V at non-inverting input(+) will create a virtual +5V at inverting input(-) terminal. My logic is that in opamps circuits we makes virtual ground at inverting input in negative feedback, when we tied non-inverting input at 0V to ground, so if i tie +5V at non-inverting terminal, it will create virtual +5V at non-inverting input.
I really appreciate, if you could answer my following questions:
- Why not connect photodiode cathodes to the 0V and similarly tie non-inverting input at 0V. As I used Analog Devices Photodiode amplifier wizard - it created a zero bias circuit for me, as you can see in the diagram below. This wizard is using the same opamp AD820.
- Why power supplies of opamp are connected with 100ohms series resistors? +5V is connected through 100Ohms resistor, similarly ground is connected through 100Ohms resistor?
