giovaniluigi
Member level 1
- Joined
- May 30, 2009
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,626
Hey guys,
I made a circuit for conditioning square waves at the range 0-10V to LVTTL.
I've used an opto-coupler to help removing noise, and to drive the opto-coupler's LED I'm using a BJT as the input's signal is weak. I also desired to create some kind of bias, where you have a tolerance for what the circuit see as low level at the input of it. I tried to use a 2.4v zenner diode to create that range, in a way that only more than 2.4V will power ON the opto-coupler's LED.
Attached there is a Picture of my schematic, but the circuit that is now in a PCB didn't work.
In the Picture above I'm introducing a square wave 0-10v in the "IN" point and I'm expecting the BJT to switch the opto-coupler.
The opto-coupler's output is digital LVTTL so I get the translation from 0-10V to LVTTL with schmitt trigger, noise immunity and with the so WANTED hysteresis (provided by zenner)
I tested before in a proto-board (same concept, but with some differents componentes) and worked.
Can you help me in trying to understand why the zenner diode is not working as I want ?
Thanks in advance.
Thanks in advance.
