XST synthesis problem
skycanny
Junior Member level 3
I have instantiated 2 gf_mult(just a kind of multiplier)in a vhdl programme,but when synthesizing it, a warning occured:
WARNING:Xst:1989 - Unit <rs_encoding>: instances <mult1>, <mult2> of unit <gf_mult> are equivalent, second instance is removed
could anyone tell me how to solve this problem and instantiate the multiplier that one of the operands is constant ?
And the following is part of the programme
Any help would be appreciate!!!
component gf_mult
generic (width : integer := 8);
port(
clk : in std_logic;
operand1 : in std_logic_vector(width - 1 downto 0);
operand2 : in std_logic_vector(width - 1 downto 0);
gf_product : out std_logic_vector(width - 1 downto 0)
end component;
mult1: gf_mult
port map(
clk => clk,
operand1 => temp1,
operand2 => "00111011", --*******???
gf_product => temp2
mult2: gf_mult
port map(
clk => clk,
operand1 => temp1,
operand2 => "00111011", --*******?????
gf_product => temp46
Sparc
Member level 5
out of reach..
Actually seeing, both mult1 & mult2 instances are doing same task, they are multiplying temp1 & "00111011". The only difference is O/P temp2 for mult1, and temp46 for mult2. Synthesize tool is smart enuff to know that:). so what it does is, it 'll just keep one instance of gf_mult and does the multiplication, but duplicates the result on both temp2 and temp46. If you 'll change the any of the operands of the two instances, it may infer two instances.
skycanny
Thanks for replies
If as you said, the sythesized resule is correspoding to my expectation?
sxqzj
Member level 4
hi skycanny
do you mean there is a finite multiplier core that can be generate dby CORE GENERATE?
