PA3040
Advanced Member level 3
- Joined
- Aug 1, 2011
- Messages
- 883
- Helped
- 43
- Reputation
- 88
- Reaction score
- 43
- Trophy points
- 1,308
- Activity points
- 6,936
Dear All,
My Xmega128A1 with HD44780 LCD program does not working
It should be much appreciated if any one can advice me
Thanks in advance
[COLOR=#008000][FONT=Courier New]/* [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] * My_first.c [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] * [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] * Created: 8/11/2013 9:49:37 PM [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] * Author: dayan [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] */ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#include <avr/io.h> [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#include <util/delay.h> [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define LCD_RS PIN4_bm /* RS on pin PC4 */ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define LCD_RW PIN5_bm /* R/W on pin PC5 */ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define LCD_E PIN7_bm /* E on pin PC7 */ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define my_led1 PIN0_bm //000000001 0x01 [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define COMM_PORT PORTC [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define DATA_PORT PORTB [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]#define BLINK_DELAY_MS 500 [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]uint8_t lcd_port [5] = {"test"}; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]uint8_t seg =0; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]uint8_t led = 0; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] void main(void){ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTF.OUTSET = 0XFF; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTF.DIRSET = 0b00001111 ; // Set pin 0 to be output. [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTJ.DIRSET = 0b11111111 ; // Set pin 0 to be output. [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTH.OUTCLR = 0Xff; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTH.DIRSET = 0b11111111 ; // Set pin 0 to be output for segments [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTC.DIRSET = 0b11111111 ; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] while(1){ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] test_led(); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_init(); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_display(); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] } [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]} [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]void lcd_init() { [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] // Initialize the AVR ports and any other hardware bits [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] DATA_PORT.OUT = 0x00; // initial data lines all low [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUT = 0X00; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] DATA_PORT.DIRSET = 0xff; // set the 8-bit data port to all outputs [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.DIRSET = 0Xff; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] // startup delay - make it long to allow time for power to settle [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] // (you want wish to remove this line) [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] _delay_ms(50); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] // LCD display initialization by instruction magic sequence [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x38); // function set [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x01); // display on/off control [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x02); //move cursor to top/left character position [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x0f); // display clear [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x06); // entry mode set [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_commnd(0x14); // Cursor shift [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]//This function sets the RS line to write data [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]void lcd_data(unsigned char value) { [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] DATA_PORT.OUT = value; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUTSET = LCD_RS; // set RS line high [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUTCLR = LCD_RW; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUTSET = LCD_E; // set E line high [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] _delay_ms(1); //_delay_ms(1); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUTCLR = LCD_E; // set E line low to latch data into LCD [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]// This function writes a byte to the LCD [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]void lcd_commnd(unsigned char value) { [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] DATA_PORT.OUT = value ; // Place data on Data Port [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] COMM_PORT.OUTCLR = LCD_RS; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]void lcd_display(){ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] unsigned int x; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] for (x=0;x<5;x++) [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] { [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] lcd_data(lcd_port[x]); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New]void test_led(){ [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTF.OUTCLR = my_led1; [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] _delay_ms( BLINK_DELAY_MS ); [/FONT][/COLOR]
[COLOR=#008000][FONT=Courier New] PORTF.OUTSET = my_led1; [/FONT][/COLOR]
Thanks in advance
