Xilinx warning: HDLParsers:3498 - No primary, secondary unit in the file
osbourne
Member level 2
when I synthesize my VHDL design, I get the following message:
WARNING:HDLParsers:3498 - No primary, secondary unit in the file "D:/Xilinx/PD/carrier_add.vhd. Ignore this file from project file "dpd_vhdl.prj".
The design works correctly, but I don't know what this message means.
Can somebody help ?
Regards,
Osbourne
xilinx warnings
Hope u have instantiated a Xilinx IP core in ur code.
In that case, u can ignore this warning..
Tool will generate a black box while synthesising this design since it is an IP Core.
Go ahead... there won't b any problem with your synthesised design.
Regards,
Renjith
    osbourne
hdlparsers:3498
yes...i think osbourne is correct...since i sometimes used to get this error in 6.3i....but it gives a black box generating warning in 7.1i.....
