// synthesis attribute STEPPING top "ES"
module top (clk, lcd_rs, lcd_rw, lcd_e, lcd_4, lcd_5, lcd_6, lcd_7);
parameter n = 27;
parameter k = 17;
(* LOC="AE14" *) input clk; // synthesis attribute PERIOD clk "100.0 MHz"
reg [n-1:0] count=0;
reg lcd_busy=1; // Lumex LCM-S01602DTR/B
reg lcd_stb;
reg [5:0] lcd_code;
reg [6:0] lcd_stuff;
(* LOC="AC17" *) output reg lcd_rs;
(* LOC="AB17" *) output reg lcd_rw;
(* LOC="AF12" *) output reg lcd_7;
(* LOC="AE12" *) output reg lcd_6;
(* LOC="AC10" *) output reg lcd_5;
(* LOC="AB10" *) output reg lcd_4;
(* LOC="AE13" *) output reg lcd_e;
always @ (posedge clk) begin
count <= count + 1;
case (count[k+7:k+2])
0: lcd_code <= 6'b000010; // function set
1: lcd_code <= 6'b000010;
2: lcd_code <= 6'b001100;
3: lcd_code <= 6'b000000; // display on/off control
4: lcd_code <= 6'b001100;
5: lcd_code <= 6'b000000; // display clear
6: lcd_code <= 6'b000001;
7: lcd_code <= 6'b000000; // entry mode set
8: lcd_code <= 6'b000110;
9: lcd_code <= 6'h24; // H
10: lcd_code <= 6'h28;
11: lcd_code <= 6'h26; // e
12: lcd_code <= 6'h25;
13: lcd_code <= 6'h26; // l
14: lcd_code <= 6'h2C;
15: lcd_code <= 6'h26; // l
16: lcd_code <= 6'h2C;
17: lcd_code <= 6'h26; // o
18: lcd_code <= 6'h2F;
19: lcd_code <= 6'h22; //
20: lcd_code <= 6'h20;
21: lcd_code <= 6'h25; // W
22: lcd_code <= 6'h27;
23: lcd_code <= 6'h26; // o
24: lcd_code <= 6'h2F;
25: lcd_code <= 6'h27; // r
26: lcd_code <= 6'h22;
27: lcd_code <= 6'h26; // l
28: lcd_code <= 6'h2C;
29: lcd_code <= 6'h26; // d
30: lcd_code <= 6'h24;
31: lcd_code <= 6'h22; // !
32: lcd_code <= 6'h21;
default: lcd_code <= 6'b010000;
endcase
if (lcd_rw)
lcd_busy <= 0;
lcd_stb <= ^count[k+1:k+0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2)
lcd_stuff <= {lcd_stb,lcd_code};
{lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff;
end
endmodule
(* LOC="AC17" *)
output reg lcd_rs; // synthesis attribute LOC lcd_rs "AC17";
input [3:0] rxd; // synthesis attribute LOC rxd "C4,D4,E1,F1";
(* LOC="C4,D4,E1,F1" *) input [3:0] rxd;
(* LOC="SLICE_X1Y0:SLICE_X1Y63",BEL="XORF" *) XORCY_L blah blah blah ;
That LCD is somewhat awkward. You will definitely need the Lumex data sheets:
https://www.lumex.com/spec.asp?p_n=LCM-S01602DTR/B
https://www.lumex.com/MstrCatalog/24_lcd_information.pdf
Here is a crude quick-and-dirty module that displays "Hello world!"
PicoBlaze is a cute little processor. Check it out someday.Code:// synthesis attribute STEPPING top "ES" module top (clk, lcd_rs, lcd_rw, lcd_e, lcd_4, lcd_5, lcd_6, lcd_7); parameter n = 27; parameter k = 17; (* LOC="AE14" *) input clk; // synthesis attribute PERIOD clk "100.0 MHz" reg [n-1:0] count=0; reg lcd_busy=1; // Lumex LCM-S01602DTR/B reg lcd_stb; reg [5:0] lcd_code; reg [6:0] lcd_stuff; (* LOC="AC17" *) output reg lcd_rs; (* LOC="AB17" *) output reg lcd_rw; (* LOC="AF12" *) output reg lcd_7; (* LOC="AE12" *) output reg lcd_6; (* LOC="AC10" *) output reg lcd_5; (* LOC="AB10" *) output reg lcd_4; (* LOC="AE13" *) output reg lcd_e; always @ (posedge clk) begin count <= count + 1; case (count[k+7:k+2]) 0: lcd_code <= 6'b000010; // function set 1: lcd_code <= 6'b000010; 2: lcd_code <= 6'b001100; 3: lcd_code <= 6'b000000; // display on/off control 4: lcd_code <= 6'b001100; 5: lcd_code <= 6'b000000; // display clear 6: lcd_code <= 6'b000001; 7: lcd_code <= 6'b000000; // entry mode set 8: lcd_code <= 6'b000110; 9: lcd_code <= 6'h24; // H 10: lcd_code <= 6'h28; 11: lcd_code <= 6'h26; // e 12: lcd_code <= 6'h25; 13: lcd_code <= 6'h26; // l 14: lcd_code <= 6'h2C; 15: lcd_code <= 6'h26; // l 16: lcd_code <= 6'h2C; 17: lcd_code <= 6'h26; // o 18: lcd_code <= 6'h2F; 19: lcd_code <= 6'h22; // 20: lcd_code <= 6'h20; 21: lcd_code <= 6'h25; // W 22: lcd_code <= 6'h27; 23: lcd_code <= 6'h26; // o 24: lcd_code <= 6'h2F; 25: lcd_code <= 6'h27; // r 26: lcd_code <= 6'h22; 27: lcd_code <= 6'h26; // l 28: lcd_code <= 6'h2C; 29: lcd_code <= 6'h26; // d 30: lcd_code <= 6'h24; 31: lcd_code <= 6'h22; // ! 32: lcd_code <= 6'h21; default: lcd_code <= 6'b010000; endcase if (lcd_rw) lcd_busy <= 0; lcd_stb <= ^count[k+1:k+0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2) lcd_stuff <= {lcd_stb,lcd_code}; {lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff; end endmodule
