Xilinx System Generator: Virtex II pro, FIR, and sysgen 10.1 compatibility
panospet
Newbie level 3
Hello,
I'm using a Virtex II pro and I want to download a design that includes the FIR block in Sysgen 10.1. As far as I can see here https://www.xilinx.com/products/software/sysgen/whatsnew.htm it says that Sysgen 10.1 includes support for Virtex 2 boards and FIR Compiler 3.2.
Unfortunately, when I try to generate a bitstream that contains the FIR block (from v1.0 to 4.0) it says that xupv2pro is not supported.
Is there any way to add a FIR block that is compatible with Virtex II Pro?
or
Is there any way to skip the FIR block and implement the same design with other compatible blocks? (to do something like convolution for example.)
Thank you,
panospet
