nilusharief003
Junior Member level 1
hi sir..when i did synthesis for alu vhdl code in xilinx tool error came as impact 585 n impact 123...it says .msk file is invalid..what does it mean?n hw to resolve?
It means, that you should provide you VHDL code that to you have helped.
https://www.xilinx.com/support/answers/22228.htm]AR #22228 - iMPACT -
some what similar to your problem ....Please Search xilinx Answer record so that you could find a better solution for the particular case
Ok please try this one
1)Impact Error 585 Fix -http://www.xilinx.com/support/answers/22160.htm
2) Impact error 123 Fix -http://www.xilinx.com/support/answers/22228.htm
