Xilinx Spartan 3 - DCM
Mudugamuwa
Newbie level 6
Newbie level 6
dcm in spartan
I want to increase the clock twice using DCM. Could anyone exactly tell me the procedure. Thanks.
Best regards,
Mudugamuwa
dcm xaw verilog instantiation
Use Xilinix Architecture Wizard(XAW). It is fully graphical so its just click-and-go. It will generate a HDL(Verilog/VHDL) file, which you can instantiate in your project. XAW also supports other architectural features that are specific to the part you are using. Incase you didn't know, XAW is accessible from the "Accessories" menu in your Start->Programs Menu.
Thanks! I could make the VHDL coding for that. But the simulation didn't give me expected results. Does simulation work fine, with the generated module?
Best regards,
Mudu
