I created a schematic file to make a FIFO buffer and added 2 modules(mux and UC code written in verilog symbols created and added to the main schematic) and made a verilog test fixture for it. After running simulation behavioral model appeared 11 errors of the same type:
ERROR:HDLCompiler:25 - "D:/.../fifo_buffer/main.vf" Line 562: Module <UC_MUSER_main> does not have a port
ERROR:Simulator:778 - Static elaboration of top level Verilog design unit(s) in library work failed
hi sandkid93
it look like the underline file doesn't seem to have the same port names as in the block diagram.
it will be easier, if you will share the all project.
