Hello all,
I've been assigned to analysis someones power budgets for a Zynq device.
At a glance the person has the BRAM operating at 5W.
The model uses the following configuration
name - uram0/tdpram
block Rams - 256
mode - ram18 (this primative...is it 18 bits or 18kilo bits?)
toggle rate - 50%
clock - 400MHz
enable rate - 100%
bit width - 18 (data bus is 16, but 8 bits are parity i believe)
write mode - read first
write rate - 50%
(port B same)
My main concern is the block rams of 256
Is this actually equating to 256 * 18K bits?
Regards,
Wes
