Xilinx JTAG Download Cable
omara007
Cairo/Egypt
xilinx jtag cable
Hi FPGA folks
I have purchased the XtremeDSP Starter Platform – Spartan-3A DSP 1800A Edition but I didn't order any download cables along with it. I would like to know my options for downloading the bitfile to the FPGA ? .. can I use a normal JTAG cable with one terminal being of USB interface (to be connected to the PC) and the other terminal being of FlyLeads (to be connected to the board) ? .. if so, what are FlyLead configuration that I should be using ?
I would also like to know if this will also work with ChipScope or not.
Thanks in advance.
xilinx jtag
I want an answer too
xilinx jtag schematic
medra said:
elsalamo 3likom dear Mohammad
My friends used the normal printer cables(jtag-usb) for DSP and it worked, I think it will work with FPGA as well.
Is there a printer cable that's JTAG-USB !!!!!!! .. why do you need JTAG with the printer ?? .. I guess you are mistaken .. the printer cable is USB-USB ..
xilinx download cable
Hi omara007
if your board is XtremeDSP Starter Platform – Spartan-3A DSP 1800A Edition.
you can connect your JTAG to J4.
BuBEE
xilinx usb download cable
BuBEE said:
Hi omara007
BuBEE
Can I use a normal general JTAG cable ? .. or should I be using Xilinx specific JTAG Downloaders ?
jtag download
if dsp C6416 uses usb-usb then you are right , but if it uses a jtag usb , than I am right.
I didn't try my self as mentioned, you won't lose any thing by asking.
salam
xilinx jtag usb
salam
What is dsp C6416?
By the way, my FPGA kit is only configured through JTAG .. hence, I can't use USB-USB even if I have it.
jtag cable
c6416 is a DSP kit.
xilinx download
omara007 said:
BuBEE said:
Hi omara007
BuBEE
i don't understand about general JTAG cable. but if you need to connect or debug xilinx FPGA you need a xilinx Cable 3(open sch.) or xilinx Cable 4 (buy from xilinx).
BuBEE
xilinx jtag download cable
I meant any JTAG-USB cable that's not specifically one of the Xilinx downloaders ..
I have been using one JTAG downloader for configuring lattice FPGA in my previous company .. I was wonder if this works
xilinx jtag programmer schematic
ok, I understand your question.
I think JTAG cable for lattice can't compatible with xilinx, but i never try.
by the way if you try that , please show your result.
Added after 9 minutes:
Hi omara007,
I attach a xilinx's jtag schematic in this post . So you can compare with your lattice's jtag schematic.
BuBEE
ps. direct link **broken link removed**
xilinx jtag download/debug cable
Thanks BuBEE ..
I just can't understand why there are hundreds of different JTAG cables .. each works for some specific DSP/uC/FPGA/CPLD family .. while JTAG itself is a standard !!
xilinx jtag schematics
omara007 said:
Hi FPGA folks
ThanFeatures:
Supported on Windows and Red Hat Enterprise Linux •
Automatically senses and adapts to target I/O voltage I
Interfaces to devices operating at 5V (TTL), 3.3V (LVCMOS), 2.5V, 1.8V, and 1.5V
LED Status Indicator • CE, USB-IF, and FCC compliant Intended for development
— not recommended for production programming
• Pb-free (RoHS-compliant) • Configures all Xilinx devices
Devices Support Details:
♦ All Virtex™ FPGA families
♦ All Spartan™ FPGA families
♦ XC9500 / XC9500XL / XC9500XV CPLDs
♦ CoolRunner™ XPLA3 / CoolRunner-II CPLDs
♦ XC18V00 ISP PROMs
♦ XCF00S / XCF00P Platform Flash PROMs
♦ XC4000 series FPGAs • Programs serial peripheral interface (SPI) flash PROMs
Package includes the following item:
1. FCPU-X USB JTAG Download cable for XILINX Devices.
2. 4 feet high speed USB cable
3. 14 pin flat cable to connect the target
4. 6 pin cable to connect the targe
website: www.e-chips.com.cn
email: sales(at)e-chips.com.cn
tel: 86-755-21002357
skype: tinali66
ks in advance.
xilinx download cable usb
The first part of the quote is already mine .. I have posted it to Xilinx forums ..
but I didn't get the rest of that starting from (ThanFeatures: )!!!
