xilinx fpga router error,can someone heip me?
shoufeng_luo
Newbie level 6
Hello everyone, I use a pair of LVDS signals as the differential clks of DCM,When implementing the design ,I encounter an error as follow:This design contains an LVDS pair.The pair of IOs must be palced in a specific relatice structure.What should I do to correct the error?Thanks !
Place pins correctly! There must be some guidelines in Xilinx's documentation for your FPGA refered to "PCB Layout" or "Pad Placement & DC Guidelines". For example, Altera's Cyclone have such restrictions:
- Single-ended inputs may be only be placed four or more pads away from a differential pad.
- Single-ended outputs and bidirectional pads may only be placed five or more pads away from a differential pad.
you are in big problem since they are dedicated pins (you probebly using GC).
the only solution i see is to use the clock as single ended clock signal.
Thanks a lot,a pair of differential signals should be connected to a pair of differential pads of fpga.But I connect them to two pads not be a pair.So the error happens.I obliged to use a sigle ended colck.
