Take a look at the almost_empty and empty signals.
I see that near to 4.2ns empty is asserted HIGH. How can you expect valid data to be out when FIFO is empty?
Your write clk is almost double that of the read clock, still the empty is being asserted but full is not asserted.
That makes me suspect your design!
Revise your wr_en and rd_en signals.
With the waveform, we can only speculate what might be wrong.
Another advice, read the spec carefully on how to use the FIFO signals.
Should I have to wait until full the fifo?
Is this like queue doesn't it? I mean the write is always write to the fifo. Then at the half speed, I read the data from the fifo.
I can't find any fail. Because the fifo is alwayes written from the input. Then when I want to read the data whenever I can do read. Am I wrong?
Yea, of course, it can be able to happen to raise the empty flag, but it that moment, even the data is written to fifo.
Then we assume that fifo does not empty. But it shows always empty at 4.2ns as you said.
Am I wrong? There is no reason to have empty flag after 4.2ns.
Also , I just want to know I've revised that signals,but the same wavefom I'v got.
We see full and empty asserted simultaneously for some time which must never happen. Could the design be overclocked?
I don't know what am I supposed to do, but as you can see the wave, the empty and full are asserted at the reset time.
