Xilinx AXI GPIO IP core
beginner_EDA
Full Member level 4
I am using AXI GPIO IP core
https://www.xilinx.com/support/documentation/ip_documentation/axi_gpio/v2_0/pg144-axi-gpio.pdf
in combination with microblaze that write/read correct data from/to VHDL top entity.
I wan to read data in microblaze from HDL top entity and do some command operation in microblaze. But the problem is whatever I read from top HDL always remains in GPIO register.
Is there any way to reset GPIO register once the data has been read in microblaze?
ads-ee
Super Moderator
Staff member
USA
You really need to improve your question asking. You usually have some vague question similar to "This morning my car doesn't start after I came home from work last night.". How is anyone supposed to answer such a question? The question itself is useless.
My guess would be you don't know how to use the GPIO and you aren't writing the registers correctly, you hooked it up wrong in your top level, or you are reading the same values because the inputs aren't changing. All of these are guesses since you didn't supply any details about how you implemented the GPIO in your design
beginner_EDA
Full Member level 4
Bravo! mr. Super Moderator
