[PIC] XC8 XLCD with PIC18 error
RUKAEF
Newbie level 2
I try to use XLCD library with default pin setup,
It compiled successfuly.
But when I simulate it gives this error.
[HD44780] Attempted to read after writing a single nibble [LCD1]
When I only use OpenXLCD command, It again gives same arror.
OpenXLCD(FOUR_BIT & LINES_5X7);
Here is my code,
#define _XTAL_FREQ 8000000
#include "confighed.h"
#include "xc.h"
#include "plib/xlcd.h"
#include "plib/delays.h"
void DelayFor18TCY(void)
Nop(); Nop(); Nop(); Nop(); // 18 cycle delay
Nop(); Nop();
return;
void Delay_Seconds(unsigned char s)
    unsigned char i,j;
    for(j = 0; j < s; j++)
        for(i = 0; i < 100; i++)__delay_ms(10);
void DelayPORXLCD(void)
   Delay1KTCYx(30);
void DelayXLCD(void)
   Delay1KTCYx(10);
void initXLCD(void){
    while(BusyXLCD());
    WriteCmdXLCD(0x06);
    WriteCmdXLCD(0x0C);
void main(void) {
    TRISB = 0;
    PORTB = 0;
initXLCD();
putrsXLCD("RUK");
while(1){
FvM
Super Moderator
Staff member
Bochum, Germany
I presume it's a Proteus simulator error message?
Check if xlcd.h is configured for 4-bit mode (the default). If this is the case, there may a problem that the simulator sees an apparent write access due to initial pin states. Or the LCD component isn't connected according to the expected pin usage.
andre_luis
Super Moderator
Staff member
Brazil
It is worthy to try adding an while(BusyXLCD()) command after each XLCD access just to check if you are having timing issues.
