xbee interfacing with 8051
monna
Newbie level 3
Newbie level 3
hello..
i am interfacing 8051 to xbee (tharang f4-it is a module from NSK )using max232 ic. when i connected the xbee to PC it works properly at 9600 .
I programmed 8051 to sent hello word at 9600 .when i connected 8051 to pc at9600 it works fine.but when i connected to pc through xbee(8051-232-232-pc) it doesn't work.where is the problem?
1)i am not using any AT commnds in the 8051. i am simply sending hello to uart. is any mistakes in the steps?is ATcommand necessary to communicate with 8051and xbee?
please help me.
where is the datasheet to the xbee module you are using? Can you post it here?
There is a setup software to configure the tharang devices.
Search and use it to configure the device to your desired network.
Sorry i dont have time to search..
ok,thanks for replay....
