Xan we program PIC24 using Assembly in the MPLAB?
lcs81
Member level 3
can we program PIC24 using assembly in the MPLAB?
Also , what is the different between PICC and HIGT TECH C?
Re: PIC24
The answer for the first question is YES. Actually, you use ASM30 which comes with MPLAB.
I don't use PICC and Hi-Tech C, sorry mate!
Cheers,
    lcs81
Re: PIC24
Salam,
PICC has almost every thing you may need as a Libraries which make it very easy to write a working code in a few lines, you even don't have to know the register names of the PIC.
HiTech is a powerfull compiler but you have to write every thing manually.
So if you want to learn embedded programming use HiTech
If you want to make a project quickly Use PICC
Regards,
    lcs81
