[SOLVED] Wrong Amplitude After FFT Calculation!
karanbanthia
Junior Member level 1
pune
Hello all,
I am not able to get the correct amplitude of input signal from DFT. My sampling frequency is 128Hz and I am take 128 Samples and computing 128-point FFT. I also have a simulated sine wave generator which I am using as input. When I vary the input frequency, FFT detects the frequency correctly till 64Hz (i.e. Fs/2) but it gives different amplitude values for different frequencies even though I am not changing the amplitude, why is this so??
I am using Blackman window and following is a part of my main code where I am calculating frequency and amplitude. I am using MPLAB C30 compiler and DSP library.
while(1)
if(startcalc==1)
  testpin = 1;
  VectorWindow(numofsamples,&storedreading[0].real,&storedreading[0].real,&windowcoeff[0]);
  FFTComplexIP (log2n, &storedreading[0], (fractcomplex *) __builtin_psvoffset(&twiddleFactors[0]), (int) __builtin_psvpage(&twiddleFactors[0]));
  BitReverseComplex (log2n, &storedreading[0]);
  SquareMagnitudeCplx(numofsamples, &storedreading[0], &storedreading[0].real);
  peak = VectorMax((numofsamples/2), &storedreading[0].real, &peakFrequencyBin);
  peaksqrt = _Q15sqrt(peak);
  utoa(txt,(unsigned int)(peaksqrt),10);
  cmd(0x80);                    // Move to 1st Row, 1st Column
  send_string(txt);          // Sends string to LCD for display
  itoa(txt,peakFrequencyBin,10);
  cmd(0xc0);                    // Move to 2nd ROw, 1st Column
  send_string(txt);
  testpin = 0;
  startcalc=0;
  TMR3 = 0x0000;
  SR = 0x0000;         // Set CPU Priority to 0
else;
Fahmy
Full Member level 2
Can yo try the flat-top window , it shall give you a better amplitude accuracy according to the attached application note .
  • fft_windowing.pdf
karanbanthia
pune
I tried flat-top as well as rectangular window too... nothing seems to help me out!
What might be the reason that I am getting variable amplitude at different frequencies even though my amplitude is constant?
