writing values of a variable to a file using verilog HDL
dll_fpga
Full Member level 3
kerala,India
how to write the values of a variable z to a text file in decimal format?
i'm using the following verilog code
integer fp1;
fp1=$fopen("ctq.txt");
$fwrite(fp1,"%d\n",z);
but the values of the variable z are still written to the file "ctq" in hexadecimal format
......but i need the values to be written to the file "ctq" in decimal format
how can this be done?
mrflibble
Advanced Member level 5
That would be really odd.... %d should really print decimal format. Just by way of sanity check...
integer fp1;
$fwrite(fp1,"Are we sure ... %d\n", 42);
$fclose(fp1);
So do you get 42 there, or 2A?
blooz
Advanced Member level 2
India
OK try this one
module fileop();
  integer fp1;
  reg [11:0]z;
 initial begin
fp1=$fopen ("ctq.txt","w");
z=12'h F_C_F;
$fclose(fp1);
end
endmodule
dll_fpga
Full Member level 3
kerala,India
integer fp1;
$fclose(fp1);
ok...fibble i got it .but i need the numbers to be written to the file in signed format .how can this be done?
integer fp1;
using %d is giving the results in unsigned format....but i need the values to be written in signed format....
mrflibble
That's a different question altogether. :p
AFAIK the moment your precious data resides in a reg or wire, you are boned. By the time the $fwrite occurs, the tool no longer knows about it being signed or unsigned.
The "integer" datatype however is signed, and will print negative numbers using %d. So as long as your data fits in a 32-bit signed, then what you could do is take your wire/reg, typecast it into an integer, and then $fwrite that integer.
---------- Post added at 20:39 ---------- Previous post was at 20:32 ----------
Did a quick test for a 32-bit wire, and works just fine.
dll_fpga
Full Member level 3
kerala,India
thanks fibble.the variable z is wire type .
ie:wire [5:0] z;
and i need the signed value of z to be written to a text file....
currently i'm using the following code
wire [5:0] z;
integer fp1;
what is the change i need to make?
can you show how can this be done using typical codes?
mrflibble
add something like:
integer signed_z;
signed_z = (z);
$fwrite(fp1,"regular z: %d\n", z);
$fwrite(fp1,"signed z: %d\n", signed_z);
But note that I tested it with 32-bits wire on purpose, that being same size operands. The integer is 32-bits as well. I have not tested it with size different from 32-bits. That's your job. :p
---------- Post added at 20:49 ---------- Previous post was at 20:44 ----------
Okay, now I did test it. And it does work for 32 bit. And does NOT work for 6 bit like your case, without some extra work.
So what you need to do is take your signed 6-bit "z", and extend it to a signed 32-bit version. And apply the above typecast trick.
blooz
India
integer fp1;
h**p://www.sutherland-hdl.com/papers/2000-HDLCon-paper_Verilog-2000.pdf
page 4
Verilog-2001 adds two new system functions,
$signed and $unsigned. These system functions are used
to convert an unsigned value to signed
Once you declare the variable as integer .it should be signed
verify with this code just modified Mrflibbbles code to illustrate the fact
no separate format specifier is needed %d is enough if you declared variable as integer .
module trb();
integer fp1;
integer  i=32'h FFFFFFFF;
initial	begin
$fwrite(fp1,"Are we sure ... %d\n",i);
i=32'h 7FFF_FFFF;
$fclose(fp1);
end
endmodule
Are we sure ... -1
Are we sure ... 2147483647
In first fwrite i is having negative sign as the MSB is 1 ,so the particular number is the 2's complement of another number (-1) .
In second one i is having Msb 0 that means a postive number.
dll_fpga
Full Member level 3
kerala,India
add something like:
integer signed_z;
signed_z = (z);
this line is giving me an error...
signed_z = (z);
---------- Post added at 09:54 ---------- Previous post was at 09:32 ----------
page 4
module trb();
integer fp1;
initial	begin
i=32'h 7FFF_FFFF;
$fclose(fp1);
end
endmodule
Are we sure ... -1
thanks blooz....i was able to solve it....
wire signed [5:0] z; //see page 4 of the pdf file given by blooz
integer fp1;
output
37
-6
