writing to flash program memory in pic18f66k22
shreyas_patel21
Full Member level 3
Hi all,
I am using PIC18f66k22 with our custom board.
I want to write flash program memory for our use.
I tried to use library function WriteBytesFlash but when I read the program memory there was no change, it is not bwing written.
I used following example code.:
void main(void)
unsigned char i;
    //Initialize Data to be written to flash
    for(i=0;i<250;i++)
        Write_Data[i]=i+1;
        Read_Data[i]=0;
    //Write data into flash from the specified location
    WriteBytesFlash((UINT32)0x6000,(UINT16)250,Write_Data);
    //Read the data to verify the writted data
    ReadFlash((UINT32)0x6000,(UINT16)250,Read_Data);
    //Erase Flash
    EraseFlash((UINT32)0x6000,(UINT32)0x7000);
    //Read the data to verify the erased data
    ReadFlash((UINT32)0x6000,(UINT16)128,Read_Data);
    WriteBlockFlash((UINT32)0x6000,4,Write_Data);
    while(1);            //End of Program
thank you,
shreyas_patel21
Full Member level 3
I dotn know this is solution or not but I could write in Flash memory using following code:
LoadFlashAddr(startaddr);
	 	i=0;
	 	while(counter--)
		 	_asm	TBLRDPOSTINC _endasm
		 	Read_Data[i] = TABLAT;
		 	i++;
	 	for(i=0;i<128;i++)
	        Write_Data[i]= a;
	        Read_Data[i]=0;
		EECON1bits.EEPGD = 1;
		EECON1bits.CFGS = 0;
		EECON1bits.WREN = 1;
		EECON1bits.FREE = 1;
		//INTCON1.GIE = 0;
		EECON2 = 0x55;
		EECON2 = 0xAA;
		EECON1bits.WR =1;
		//INTCONbits.GIE = 1;
		_asm  TBLRDPOSTDEC 	_endasm
		counter = SIZE_OF_BLOCK;
		i=0;
		while(counter--)
			TABLAT = Write_Data[i];
			_asm  TBLWTPOSTINC 	_endasm
			i++;
		EECON2 = 0x55;
		EECON2 = 0xAA;
		EECON1bits.WR =1;
		EECON1bits.WREN = 0;
thank you,
I am trying to find why the example code(in 1st post in this thread) given in library did not work..
yuvko
Member level 4
i think you should init the flash for writing before trying to write to it. i.e:
//INTCON1.GIE = 0;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1bits.WR =1;
