Writing program for 8051 in C & assembly for communication protocol
Khan740
Junior Member level 2
I want to know how to write a program in assembly and C (for 8051 microcontroller) for the communication protocol, As shown below:
SOC Ack LOD Ack DATA Ack EOC
where;
SOC: Start of communication
Ack: Acknowledgment to remote station
LOD: Length of data
EOC: End of Conversion
  • Program in assembly and in C is required for the following communication protocol.doc
flashking
Full Member level 3
you will need a compiler for the microcontroller
I suggest keil mvision, https://www.keil.com/demo/eval/c51.htm
also an easier one is MikroC which has a lot of manuals, mikroC PRO for 8051 2009 - C compiler for 8051 microcontroller - mikroElektronika
using the serial port is some what easy
you need a master and a slave microcontroller
the master will have two predefined bytes (SOC ,EOD) and (ACK) to compare the received ACK with it
the data will be taken from any source and you can get its length from STRLEN function or a for loop in C , or an incremet command in assembly.
on the contrary, as for the slave it will have one (ACK) to be sent and two (SOC, EOC) to compare the received ones with
it will store the data using a for loop that loops LOD number of times.
Khan740
Please send me a sample of code, if you can.
