[SOLVED] Writing out a LayerMap file PnR tool along with gds
wipshami
Member level 1
Member level 1
how can I write out a layer map file from encounter along with gds from ? Is it with the switch -layermap with streamOut, Or is it taking layerMap as input ?
Thanks
Shameel
it is something like this:
METAL1		NET		16	0
METAL1		SPNET		16	0
METAL1		PIN		16	0
METAL1		LEFPIN		16	0
METAL1		FILL		16	1
METAL1		VIA		16	0
METAL1		VIAFILL		16	1
METAL1		LEFOBS		16	0
METAL1		CUSTOM		40	0
NAME		METAL1/NET	16	0
NAME		METAL1/SPNET	16	0
NAME		METAL1/PIN	40	0
NAME		METAL1/LEFPIN	40	0
LEF name, data type, gds layer, gds second level data-layer
ok..but can I write out this from PnR tool along with gds or do I need to create this manually ?
you write it manually, as for encounter the number of layers is limited (metals and vias)
