RobinAmerica
Newbie level 3
I hope i'm posting this to the right area, it seemed to fit in a few different areas, but since the main issue is related to drawing max power allowed from the PSU, i thought this the best fit.
I'm interested in high power LEDs and how far they've come to minimize power expenditure, and i've been learning a ton over the past year about how to implement simple circuits to take advantage of them. I do have some very basic experience with electronics and troubleshooting problems, mainly of the most basic type. There are some things that seem to go right over my head, i was hoping to get some help. Safety has always been the #1 topic for me, and so i'm also interested in doing things correctly.
I bought quite a few of the inexpensive "generic chinese led emitters" off ebay. That might seem to contradict the last sentence, but i've found them very safe, even if not very efficient. But being so inexpensive, i thought it better to start with these, this way when i screw something up, i don't take the bank account out with it.
My main interest right now is in using computer power supplies as the main power source- they're relatively inexpensive, reliable and safe (assuming name brand/ul listed etc).
Here is one of the LEDs i am using:
There's a lot to say, but without writing a book.. this led has been hard to learn with. I didn't notice until recently (and after i had spent a ton of time learning to work out the math for resistors etc..) that different sellers on ebay have completely different specs for what appears to be the same LED. Unsafe to start with. One seller will have it listed as 300mA per channel, another says 700mA per channel. I know there is some wiggle room with the specs, but that's rediculous, and hard to know how to wire it up safely, while getting the most light out of it possible.
Anyway, i do have nine of them wired up to a controller, which is powered by a computer power supply. This was the first project i made, and i did the usual beginner attitude- who needs a constant current controller? Don't be rediculous, a simple resistor does the job and seems to work fantastic. And it's still working just fine. The obvious problem, the resistors are trashing the majority of the current through heat (well not to mention that these LEDs are inefficient to begin with, but that's beside the point). The system works fine as it is, i can do everything i was hoping to with it, but being so inefficient, i started looking at constant current controllers.
That's what i'm using now. I have one 3 channel controller for each LED. The constant voltage controller i used before had several channels, so i just hooked the leds to it and didn't have to worry much about circuit design. But since these wire together differently, i'm finding out how much i thought i knew but didn't.
The controllers have +/- power in, work with a min of 12vdc, have a negative out for each channel, and a common (for all of the + channels).
What i would like to do is have for example, have two white LEDs and two of these colored RGB LEDs hooked into the same fixture under the same lens for options in color. The two white and the two colored would each be controlled as if the pair were one LED.
I think that means that the two white LEDs would be hooked in series, and the two colored LEDs would be hooked in series, but i'm a little confused how to hook them up other than that. I'm finding that there are a lot of other things to think about too, but determined to walk slowly through this and learn my way through it.
I was hoping to, at some point, have more than one of these fixtures powered off the same PSU. I've been able to power 9 rgb LEDs so far off the same supply. How do you calculate how many can be safely powered? I've looked, and there is some bad info out there! If i have a PSU that supplies 20 amps at 12v, it's not as simple as using 20 amps to calculate it apparently because power supplies will divide their power differently between rails, or is this correct? In other words, can a single molex coming out of the PSU supply the full 500watts (or whatever) that the PSU is rated to? I know that you should keep constant loads down to 80% of the rated max..
I've heard it both ways, but that leads me to the next question, all of the wires coming out of the PSU indicate they are 18gauge.
Some sites say 18 gauge can carry 2.3 amps safely:
http://www.powerstream.com/Wire_Size.htm
Some say it can only carry 10 amps:
http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity
Here's one that says 16 amps:
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/wirega.html
How do i know which table to go by?
Thanks for reading, any help would be appreciated.
Rob
Rob
