hello.
I have a verilog code for r single port ram :
Code Verilog - [expand] | |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33 | module RAM (
clk,
we,
en,
addr,
din,
dout
input clk;
input we;
input en;
input [5:0] addr;
input [15:0] din;
output [15:0] dout;
reg [15:0] RAM [63:0];
reg [15:0] dout;
always @(posedge clk)
begin
if (en)
begin
case (we)
1'b1 : RAM[addr] <= din;
1'b0 : dout <= RAM[addr];
endcase
end
end
endmodule |
when I do the xst analyse in ISE I have this result:
Minimum period: 1.535ns (Maximum Frequency: 651.529MHz)
Minimum input arrival time before clock: 3.472ns
Maximum output required time after clock: 3.597ns
Maximum combinational path delay: No path found
and everything is ok when I run post place route simulatin and I can see the write and read operations
but when I choose word's length like this :
1 | reg [63:0] RAM [63:0]; |
when I run xst analyse I have this ressult:
Minimum period: No path found
Minimum input arrival time before clock: 2.324ns
Maximum output required time after clock: 5.000ns
there is no value for minimum period
and when I run post place route simulation all results are zero(read operation).
could anyone help me?
I really need to write a code which word's length is at least 256 and it should be high speed enough.
I used spartan 6 XC6SLX75 for my project.
and this is my testbench:
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64 | module testbench;
// Inputs
reg clk;
reg we;
reg en;
reg [5:0] addr;
reg [31:0] din;
// Outputs
wire [31:0] dout;
// Instantiate the Unit Under Test (UUT)
state_metric_RAM uut (
.clk(clk),
.we(we),
.en(en),
.addr(addr),
.din(din),
.dout(dout)
always begin
clk = 1'b0;
#5;
clk = 1'b1;
#5;
end
initial begin
en = 1'b1;
#10;
end
initial begin
#107;
din = 32'h0000111d;
addr = 6'b000100;
we = 1'b1;
#11;
din = 32'h00000011;
addr = 6'b010000;
we = 1'b1;
#10;
din = 32'h0101abcd;
addr = 6'b000010;
we = 1'b1;
#10;
addr = 6'b000100;
we = 1'b0;
#10;
addr = 6'b010000;
we = 1'b0;
#10;
addr = 6'b000010;
we = 1'b0;
#10;
addr = 6'b000100;
we = 1'b0;
#10;
end
endmodule |
