Witch power for Virtex4 bank
voho
Full Member level 2
Nador City
hi all,
how to chose power 3.3v,2.5v,1.8v???? for the different virtex4FX bank.
thank's regards
echo47
Advanced Member level 5
USA
You choose VCCO according to the requirements of whatever external devices you've connected to the FPGA I/O pins.
Here's a relevant section from chapter "SelectIO Resources" in the Virtex 4 User Guide UG070:
Output Drive Source Voltage (VCCO) Pins
Many of the low-voltage I/O standards supported by Virtex-4 devices require a different output drive voltage (VCCO). As a result, each device often supports multiple output drive source voltages.
Output buffers within a given VCCO bank must share the same output drive source voltage. The following input buffers use the VCCO voltage: LVTTL, LVCMOS, PCI, LVDCI and other DCI standards.
