This transmitter when paired with our 5.8Ghz receiver can reach 2 km range with standard 2dBi dipole antennas. A fantastic combo! Will not interfere with 2.GHz R/C systems and is legal to use all over the world (amateur frequency band).
To use this transmitter module requires a little bit of soldering. You must cut the coax or cable to correct length and solder it to the transmtter as the antenna.
