dhruv_electro
If you plan to use zigbee go for PIC MCUs (lots of options). and use Zigbee module of same manufacturer, But you can consider any microcontroller. Yes 8051 is easy to start.
i had used lm35 for temp, humidity sensor for land humidity sendor and LDR for light.. and used a robot that moved on a line ( liike line following robot) and would transmit the parameters after stopping for a while and transmitting the data... the data is received on the othe end using a zigbee... and a LED is turned on or a fan is started, or something ... that was the green house project i did for my students... Is it the same thing you also wish to do... i used zigbee for the project...
