wireless communication with FPGA
Argoth
Newbie level 3
Czech Republic
Hello,
I am trying realize wireless communication between two devices.
I have never done something like that and as a beginner I don't understand how some things work so I need your help.
I am using:
- Nexys 3 board with Spartan 6 FPGA
http://www.digilentinc.com/Products...5b85a628e-21AA2222-5056-0201-02D6A08418D6FF8E
- PmodRF2 transceiver
http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,401,927&Prod=PMOD-RF2
On PmodRF2 there is microchip MRF24J40 that communicates with a host mictrocontroller via a 4 wire SPI port as a slave device. Microchip is an IEEE 802.15.4 Standard compliant 2.4 GHz RF transceiver and it integrate the PHY and MAC functionality.
So I guess I need write SPI master in FPGA something like... http://www.eewiki.net/display/LOGIC/Serial+Peripheral+Interface+(SPI)+Master+(VHDL)
And this I use for writing and reading data.
Now comes the part where I stopped. In MRF24J40 is implemented static RAM that looks like that.
There are some control registers and I have no Idea how to use them. I know that there is some short and long address register interface. So could you please tell me how to use it. For example:
According to MRF24J40 manual I need initialize MRF24J40 like this:
1. SOFTRST (0x2A) = 0x07 – Perform a software Reset. The bits will be automatically cleared to ‘0’ by hardware.
2. PACON2 (0x18) = 0x98 – Initialize FIFOEN = 1 and TXONTS = 0x6.
3. TXSTBL (0x2E) = 0x95 – Initialize RFSTBL = 0x9.
4. RFCON0 (0x200) = 0x03 – Initialize RFOPT = 0x03.
5. RFCON1 (0x201) = 0x01 – Initialize VCOOPT = 0x02.
6. RFCON2 (0x202) = 0x80 – Enable PLL (PLLEN = 1).
7. RFCON6 (0x206) = 0x90 – Initialize TXFIL = 1 and 20MRECVR = 1.
8. RFCON7 (0x207) = 0x80 – Initialize SLPCLKSEL = 0x2 (100 kHz Internal oscillator).
9. RFCON8 (0x208) = 0x10 – Initialize RFVCO = 1.
10. SLPCON1 (0x220) = 0x21 – Initialize CLKOUTEN = 1 and SLPCLKDIV = 0x01.
I think that I should move register on adress 0x2A to adress 0x07. Is it right? And if yes, how?
And another thing for example with channel selection. There is some RFCON0 (0x200) register. I choose channel and according to this I should set value like ,,0x03,, into RFCON0 (0x200<7:4>). So it is value 0011 in bits 7 6 5 4 ? And how to do that?
The problem is that I dont know what to send through SPI and how it should looks like in VHDL.
Thanks for help
You are writing to control registers by sending a SPI frame according datasheet figure 2-8 (short address write) respectively figure 2-10 (long address write). Try to understand how address and data value are packed into the SPI frame, that's independend of FPGA design problems.
Secondly you'll design a SPI master interface that's capable of reading and writing short and long address format frames.
Then design a state machine that is sequentially performing the initialization. It's most reasonable to read address and data pairs from a ROM table.
Initialization is probably the easy part. Transmitting and receiving involves exchange of data with multiple FIFOs. That's surely possible in VHDL (hardware design) but a rather complex action and clearly beyond the scope of a beginners project.
Registers are saved in the static RAM? so when I want to work with Short register I send SPI packet of 8 bits that indicates that it's 0 for short address, address of register and 0 or 1 for reading or writing and then I can read or write another 8 bits?
I hope I am not totaly wrong.
Can you tell me where I can find something about packeting into the SPI frames? I think it's not in the MRF24J40 Data sheet.
Ok, thank you and don't you about someone who did something like that and published his work?
There is some example C code out there that you can use for inspiration. That way you have an example of initialization procedures. A bit of googling / looking at the product page on microchip.com should get you there.
If you cannot find it I'll google it and post the result with a time delay designed as an incentive to cultivate your search skills. ;-)
