Sunny55
Full Member level 3
Hi, i am working on a circuit that is used to measure the battery's voltage. The battery is rated at 12V,100Ah. My question is can i use normal size jumper wires or do i need to go for thicker wires? What is the difference if i use thicker wires for the circuit compared to normal wires? Would thicker wires damage the components due to its wire width?(Just assuming).
I know its silly but for safety i would want to use the correct wire.
Thanks.
Thanks.
