willman microcontroller programer kit
gtp usb pcb
I have only 18f4550, and can't find others at this time (and maybe so far). So, can I use 4550 for above gtp usb schematic with the same hex file? I read in datasheet and nothing is diffenrent excepts memory Smile
The 18F2550 is a 28-pin device. The 18F4550 is a 40-pin device. The 2550 has fewer I/O pins and fewer ADC channels. They are otherwise identical. They have the same amount of code ROM, data ROM, RAM, and other than as stated above, the same peripherals.
Since the 4550 has more pins, you would have to change the layout to accommodate the larger chip. IMHO, more trouble than it is worth. Besides, you can't get the firmware for the plus version. You must purchase a 2550 with firmware installed.
Peace,
Computerman29
gtp-usb[plus]
and now I think you must purchase the complete kit... the pic preprogrammed is not available anymore...
ali3nworld gtp usb
hello all and thanks about your efforts,
i want to ask about the source file of the firmware how can i get it?
Added after 1 minutes:
hellooooooooooooooo
any body her
gtp-usb [plus] hex
please read the thread from the beginning...
you can only buy the preprogrammed pic18f2550...
you can't buy the hex file...
so you can't also get the firmware !
gtp-usb [ plus ]
MODERATOR ACTION: the thing which are freely on net do not upload
i have the version GTP USB lite
the file include .hex file for the pic 18f2550
gtp-usb plus firmware
hassan1980 said:
Where is the schematic for this programmer?
www.sprut.de/electronic/soft/usburn/usburn.htm
I am waiting your replies
schematic
pcb design
layout design
pcb design in eagle format
part list
strip board plan
latest software and firmware for pic
gtp usb summer 2005
this is your usb gtp schematic
gtp usb plus hybrid
GTP USB LITE need external power supply??? How many volts must be it???
thanks
gtp usb 232
anyone know configuration bit to program pic18f2550 firmware .... for GTP USB Lite.....
pic gtp-usb
does anyone have SMD layout for GTP USB Lite?
gtp icsp problem
Instead of building a third party programmer, with the addition of only a few parts you can build a PICkit 2 clone SE, see my Junebug post in these forums. The Junebug contains a simplified PK2 clone (18F2550) and a PIC Tutor on the same PCB.
usb shema for voltage
Thanks Bloeroomelectronics, seems like a nice tool.
I am still curious about the SMD version of GTP-USB Lite.
on my first trial i used smd BAS16 instead of 1N4148 diodes and smd BC847B instead of BC548. so i get the know problem with the programmer passing the test but when i try to read, write, detect the device shuts down with a known "Error - No is answer of hardware"
After making one according to details from https://ali3nworld.blogspot.com/ i ran into the same problem.
please help.
gtp usb lite pcb
I can't help you with the GTB and I can fathom why anyone would build it anymore. A bare bones PK2 clone is almost the same design, supports MPLAB, has a debugger for many 16F & 18F PICs, does not require a special driver for the USB (it's a HID device) gets software updates from Microchip...
Same 18F2550 as the GTB just a couple more transistors and an inductor for a superior and programmable VPP pump. (The GTB is a fixed voltage tripler design)
schematic gtp usb lite download free
ne moz to bez kabla
Added after 9 minutes:
bije na masu
gtp-usb-lite
hi electronics,
i have built gtp usb lite from http://ali3nworld.googlepages.com/download
first time it didn´t worked, my notebook asus a6km with sis chipset didn´t communicate good, i had to buy kouwell 2002-2 with 2 usb ports and chipset via, now it si perfect
you can program firmware first by gtp 3.55g with jdm, it works good, crystal i have tried 4, 10, 12 and 20 mhz, you must only set it in the config word
when programming
gtp usb lite is very fast, i recommend
meet in silicon hell :-D
Added after 14 minutes:
the error by me was the same, as described above, detection was good, but read or write - "Error - No is answer of hardware"
the main problem is in usb in pc
add cond. 10-100uf into vdd-vss, it is better connection
Added after 10 minutes:
i have add yet resistor 20k on rb3-to-vss, because base voltage of the transistor was about 0.5v in off status
gtp-usb plus scchematic
1bastl thanks,
I have already had a 100uF/25v from VDD to ground. will it help if i buy a USB hub with a power adapter?
18f2550 usb chip schematics
hello nodirbek,
i have tested with usb hub starhub201 from msi and when pc usb chipset didn´t work, hub didn´t too
when you use any hub with external power, i don´t know, but i thing, it will not function
maybe the easiest way could be to try gtp usb lite on other computers, one friend tested it on nvidia nforce and it didn´t worked
as i have said, to me it works with via chipsets, it is probably in better communications protocol or 18f2550 supports only some chipsets...
Added after 51 minutes:
one more note:
i have a usb-to-serial cable, on sis usb chipset it works, but the connection is about 50 pct, on my new via usb controller it is 100 pct
winpic800 schematic
Thanks. I will try to make a parallel pic programmer. any one knows an easy pic programmer for dsPIC chips?
