will get antena effect in poly
saran826
Newbie
Newbie level 3
If I used poly for interconnecting 2 gates of long distance will i get antenna effect?please explain the answer in detail.
Thanks in advance
Thanks in advance
Technically, you could. If the process utilizes CMP, of course. But how likely are you to use poly to route long distances? I am sure you will bump into DRC violations before you bump into antenna violations.
