Widely used mosfets in SMPS & easily available
I_think
Member level 5
I am looking for mosfets with reverse voltage of 500V or more. Which are commonly used in smps.
When I find mosfet from net that would suit my design, and ask shop keeper they say its not available with them.
So I am trying to find the list of mosfet those are generally used in smps. This will help me in getting the mosfets with local shopkeepers.
Request you all to contribute to this thread.
Some examples for the N- MOSFET >500V
2SK2700 Transistor: unipolar, N-MOSFET; 900V; 3A; 40W; TO220IS |
2SK2843 Transistor: unipolar, N-MOSFET; 600V; 10A; 45W; TO220IS |
2SK3565 Transistor: unipolar, N-MOSFET; 900V; 5A; 45W; TO220 |
FQP2N60C Transistor: unipolar, N-MOSFET; 600V; 2A; TO220 |
IRFB9N60APBF Transistor: unipolar, N-MOSFET; 600V; 9.2A; 170W; TO220AB |
IRFBC30PBF Transistor: unipolar, N-MOSFET; 600V; 3.6A; 74W; TO220AB |
IRFBC40PBF Transistor: unipolar, N-MOSFET; 600V; 6.2A; 96W; TO220AB |
IRFBE30PBF Transistor: unipolar, N-MOSFET; 800V; 4A; 125W; TO220AB |
IRFBF30 Transistor: unipolar, N-MOSFET; 900V; 3.6A; 125W; TO220AB |
IRFBG20PBF Transistor: unipolar, N-MOSFET; 1kV; 1.4A; 54W; TO220AB |
IRFBG30PBF Transistor: unipolar, N-MOSFET; 1kV; 3.1A; 125W; TO220AB |
IRFIBC30GPBF Transistor: unipolar, N-MOSFET; 600V; 2.5A; 35W; TO220ISO |
IRFPC50PBF Transistor: unipolar, N-MOSFET; 600V; 10A; 180W; TO247AC |
IRFPC60PBF Transistor: unipolar, N-MOSFET; 600V; 16A; 280W; TO247AC | | |
IRFPE40PBF Transistor: unipolar, N-MOSFET; 800V; 5.4A; 150W; TO247AC |
IRFPE50PBF Transistor: unipolar, N-MOSFET; 800V; 7.8A; 190W; TO247AC |
IRFPF40PBF Transistor: unipolar, N-MOSFET; 900V; 4.7A; 150W; TO247AC |
IRFPF50PBF Transistor: unipolar, N-MOSFET; 900V; 6.7A; 190W; TO247AC |
IRFPG50PBF Transistor: unipolar, N-MOSFET; 1kV; 6.1A; 190W; TO247AC |
IXFH12N100Q Transistor: unipolar, N-MOSFET; 1kV; 48A; 300W; TO247AD |
IXFH13N80 Transistor: unipolar, N-MOSFET; 800V; 13A; 300W; TO247AD |
IXFH15N80Q Transistor: unipolar, N-MOSFET; 800V; 15A; 300W; TO247AD |
IXFH26N60Q Transistor: unipolar, N-MOSFET; 600V; 26A; 360W; TO247AD |
IXFH6N100 Transistor: unipolar, N-MOSFET; 1kV; 6A; 180W; TO247AD |
IXTH5N100A Transistor: unipolar, N-MOSFET; 1kV; 5A; 180W; TO247AD |
P7NB60FP Transistor: unipolar, N-FET; 600V; 4.1A; 40W; TO220 |
SPA07N60C3 Transistor: unipolar, N-MOSFET; 600V; 7.3A; 32W; TO220FP |
SPP04N80C3 Transistor: unipolar, N-MOSFET; 800V; 6A; TO220 |
SPP06N80C3 Transistor: unipolar, N-MOSFET; 800V; 6A; 83W; TO220 |
SPP12N50C3 Transistor: unipolar, N-MOSFET; 560V; 11.6A; 125W; TO220 |
SPP20N60C3 Transistor: unipolar, N-MOSFET; 650V; 20.7A; 208W; TO220 | | |
SPP20N60S5 Transistor: unipolar, N-MOSFET; 600V; 20A; 208W; TO220 |
SPW47N60C3 Transistor: unipolar, N-MOSFET; 650V; 47A; 415W; TO247 |
STF3NK80Z Transistor: unipolar, N-MOSFET; 800V; 2.5A; TO220FP |
STGW20NC60VD Transistor: unipolar, N-MOSFET; 600V; 30A; 200W; TO247 |
STP10NK60Z Transistor: unipolar, N-MOSFET; 600V; 10A; 115W; TO220 |
STP10NK60ZFP Transistor: unipolar, N-MOSFET; 600V; 10A; 35W; TO220ISO |
STP10NK80ZFP Transistor: N-MOSFET; 800V; 9A; 40W; TO220FP |
STP11NM60FDFP Transistor: unipolar, N-MOSFET; 600V; 11A; 35W; TO220FP |
STP11NM80 Transistor: unipolar, N-MOSFET; 800V; 11A; 150W; TO220 |
STP12NM50FP Transistor: unipolar, N-MOSFET; 550V; 12A; 35W; TO220FP |
STP20NM60FD Transistor: unipolar, N-MOSFET; 600V; 20A; 45W; TO220 |
STP3NK90Z Transistor: unipolar, N-MOSFET; 900V; 3A; 90W; TO220 |
STP4N150 Transistor: unipolar, N-MOSFET; 1.5kV; 4A; 160W; TO220 |
STP4NK60Z Transistor: unipolar, N-MOSFET; 600V; 4A; 70W; TO220 |
STP4NK60ZFP Transistor: unipolar, N-MOSFET; 600V; 4A; 25W; TO220FP |
STP4NK80Z Transistor: unipolar, N-MOSFET; 800V; 3A; 80W; TO220 |
STP5NK80Z Transistor: unipolar, N-MOSFET; 800V; 4.3A; 110W; TO220 |
STP5NK80ZFP Transistor: unipolar, N-MOSFET; 800V; 4.3A; 30W; TO220ISO |
---------- Post added at 23:31 ---------- Previous post was at 22:55 ----------
and the list may continue:
2SK3562 TOSHIBA N Channel 6A 600V 1.25ohm 10V 4V 40W TO-220SIS
2SK3565 TOSHIBA N Channel 5A 900V 2.5ohm 10V 4V 45W TO-220SIS
2SK3566 TOSHIBA N Channel 2.5A 900V 6.4ohm 10V 4V 40W TO-220SIS
2SK3567 TOSHIBA N Channel 3.5A 600V 2.2ohm 10V 4V 35W TO-220SIS
2SK3569 TOSHIBA N Channel 10A 600V 0.75ohm 10V 4V 45W TO-220SIS
2SK3681-01 FUJI N Channel 43A 600V 0.16ohm 10V 5V 600W TO-247
2SK3767 TOSHIBA N Channel 2A 600V 4.5ohm 10V 4V 25W TO-220SIS
2SK3797 TOSHIBA N Channel 13A 600V 0.43ohm 10V 4V 50W TO-220SIS
2SK3799 TOSHIBA N Channel 8A 900V 1.3ohm 10V 4V 50W TO-220SIS
FCP11N60 FAIRCHILD SEMICONDUCTOR N Channel 11A 650V 0.32ohm 10V 5V 125W TO-220
FCP11N60F FAIRCHILD SEMICONDUCTOR N Channel 11A 650V 0.38ohm 10V 5V 125W TO-220
FCP4N60 FAIRCHILD SEMICONDUCTOR N Channel 3.9A 600V 1ohm 10V 5V 50mW TO-220
FCPF11N60 FAIRCHILD SEMICONDUCTOR N Channel 11A 600V 0.32ohm 10V 5V 36W TO-220F
FCPF20N60 FAIRCHILD SEMICONDUCTOR N Channel 20A 600V 0.15ohm 10V 5V 39W TO-220F
FCPF7N60 FAIRCHILD SEMICONDUCTOR N Channel 7A 600V 0.53ohm 10V 5V 31W TO-220F
FQP10N60C FAIRCHILD SEMICONDUCTOR N Channel 9.5A 600V 0.6ohm 10V 4V 156W TO-220
FQP12N60C FAIRCHILD SEMICONDUCTOR N Channel 12A 600V 0.53ohm 10V 4V 225W TO-220
FQP2N60C FAIRCHILD SEMICONDUCTOR N Channel 1.35A 600V 3.6ohm 10V 4V 54W TO-220
FQP3N80C FAIRCHILD SEMICONDUCTOR N Channel 3A 800V 4ohm 10V 5V 107W TO-220
FQP5N80 FAIRCHILD SEMICONDUCTOR N Channel 4.8A 800V 2.6ohm 10V 5V 140W TO-220
FQP6N80 FAIRCHILD SEMICONDUCTOR N Channel 5.8A 800V 1.95ohm 10V 5V 158W TO-220
FQP6N80C FAIRCHILD SEMICONDUCTOR N Channel 5.5A 800V 2.1ohm 10V 5V 158W TO-220
FQP6N90C FAIRCHILD SEMICONDUCTOR MOSFET, N, TO-220 Channel 6A 900V 1.93ohm 10V
FQP7N80C FAIRCHILD SEMICONDUCTOR N Channel 6.6A 800V 1.57ohm 10V 5V 167W TO-220
FQP8N60C FAIRCHILD SEMICONDUCTOR N Channel 7.5A 600V 1ohm 10V 4V 147W TO-220
FQP9N90C FAIRCHILD SEMICONDUCTOR N Channel 8A 900V 1.12ohm 10V 5V 205W TO-220
FQPF12N60C FAIRCHILD SEMICONDUCTOR N Channel 12A 600V 0.65ohm 10V 4V 51W TO-220F
FQPF2N60C FAIRCHILD SEMICONDUCTOR N Channel 2A 600V 4.7ohm 10V 4V 23W TO-220F
FQPF2N80 FAIRCHILD SEMICONDUCTOR N Channel 1.5A 800V 6.3ohm 10V 5V 35W TO-220F
FQPF3N80C FAIRCHILD SEMICONDUCTOR N Channel 3A 800V 4.8ohm 10V 5V 39W TO-220F
FQPF5N60C FAIRCHILD SEMICONDUCTOR N Channel 4.5A 600V 2.5ohm 10V 4V 33W TO-220F
FQPF6N60C FAIRCHILD SEMICONDUCTOR N Channel 5.5A 600V 2ohm 10V 4V 40W TO-220F
FQPF6N80C FAIRCHILD SEMICONDUCTOR N Channel 5.5A 800V 2.5ohm 10V 5V 51W TO-220F
FQPF6N80C. FAIRCHILD SEMICONDUCTOR N Channel 3.3A 800V 1.95ohm 10V 5V 51W TO-220F
FQPF8N60C FAIRCHILD SEMICONDUCTOR N Channel 7.5A 600V 1.2ohm 10V 4V 48W TO-220F
FQPF8N80C FAIRCHILD SEMICONDUCTOR N Channel 8A 800V 1.55ohm 10V 5V 59W TO-220F
IPA50R140CP INFINEON N Channel 23A 550V 0.14ohm 10V 3V 34W TO-220
IPA50R250CP INFINEON N Channel 13A 550V 0.25ohm 10V 3V 33W TO-220
IPA50R299CP INFINEON N Channel 12A 550V 0.299ohm 10V 3V 104W TO-220
IPA50R350CP INFINEON N Channel 10A 550V 0.35ohm 10V 3V 32W TO-220
IPA50R399CP INFINEON N Channel 9A 550V 0.399ohm 10V 3V 83W TO-220
IPA50R520CP INFINEON N Channel 7.1A 550V 0.52ohm 10V 3V 66W TO-220
IPA60R125CP INFINEON N Channel 25A 650V 0.125ohm 10V 3V 35W TO-220
IPA60R199CP INFINEON N Channel 16A 650V 0.199ohm 10V 3V 34W TO-220
IPA60R250CP INFINEON N Channel 12A 650V 0.25ohm 10V 3V 33W TO-220
2K1119(F) TOSHIBA N Channel 4A 1kV 3.8ohm 10V 3.5V 100W TO-220AB
FCH22N60N FAIRCHILD SEMICONDUCTOR N Channel 22A 600V 0.14ohm 10V 3V 205W TO-247
FCH25N60N FAIRCHILD SEMICONDUCTOR N Channel 25A 600V 0.108ohm 10V – 216W TO-247
FCH35N60 FAIRCHILD SEMICONDUCTOR N Channel 35A 600V 0.079ohm 10V – 312.5W TO-247
FCH47N60_F133 FAIRCHILD SEMICONDUCTOR N Channel 47A 600V 0.058ohm 10V – 417W TO-247AB
FCH47N60F_F133 FAIRCHILD SEMICONDUCTOR N Channel 47A 600V 0.062ohm 10V – 417W TO-247AB
FCH47N60N FAIRCHILD SEMICONDUCTOR N Channel 47A 600V 0.0515ohm 10V – 368W TO-247
FCH47N60NF FAIRCHILD SEMICONDUCTOR N Channel 45.8A 600V 0.0575ohm 10V – 368W TO-247
FCH76N60N FAIRCHILD SEMICONDUCTOR N Channel 76A 600V 0.028ohm 10V – 543W TO-247
FCH76N60NF FAIRCHILD SEMICONDUCTOR N Channel 72.8A 600V 0.0287ohm 10V – 543W TO-247
FCP11N60N FAIRCHILD SEMICONDUCTOR MOSFET,N CH,600V,10.8A,TO220
FCP13N60N FAIRCHILD SEMICONDUCTOR MOSFET,N CH,600V,13A,TO220
FCP16N60N FAIRCHILD SEMICONDUCTOR MOSFET,N CH,600V,16A,TO220
FCP22N60N FAIRCHILD SEMICONDUCTOR MOSFET,N CH,600V,22A,TO220
FCP25N60N_F102 FAIRCHILD SEMICONDUCTOR N Channel 25A 600V 0.107ohm 10V – 216W TO-220
FCP36N60N FAIRCHILD SEMICONDUCTOR N Channel 36A 600V 0.081ohm 10V – 312W TO-220
FCP9N60N FAIRCHILD SEMICONDUCTOR N Channel 9A 600V 0.33ohm 10V – 83.3W TO-220
FCPF11N60NT FAIRCHILD SEMICONDUCTOR N Channel 10.8A 600V 0.255ohm 10V – 32.1W TO-220F
FCPF13N60NT FAIRCHILD SEMICONDUCTOR N Channel 13A 600V 0.244ohm 10V – 33.8W TO-220F
FCPF16N60NT FAIRCHILD SEMICONDUCTOR N Channel 16A 600V 0.17ohm 10V – 35.7W TO-220F
FCPF7N60NT FAIRCHILD SEMICONDUCTOR N Channel 6.8A 600V 0.46ohm 10V – 30.5W TO-220F
FCPF9N60NT FAIRCHILD SEMICONDUCTOR N Channel 9A 600V 0.33ohm 10V – 29.8W TO-220F
FDP10N60NZ FAIRCHILD SEMICONDUCTOR N Channel 10A 600V 0.64ohm 10V – 185W TO-220
FDP12N60NZ FAIRCHILD SEMICONDUCTOR N Channel 12A 600V 0.53ohm 10V – 240W TO-220
FDP7N60NZ FAIRCHILD SEMICONDUCTOR N Channel 6.5A 600V 1.05ohm 10V – 147W TO-220
FDPF17N60NT FAIRCHILD SEMICONDUCTOR N Channel 17A 600V 0.29ohm 10V – 62.5W TO-220F
FDPF5N60NZ FAIRCHILD SEMICONDUCTOR N Channel 4.5A 600V 1.65ohm 10V – 33W TO-220F
IPA60R125C6 INFINEON N Channel 30A 600V 0.11ohm 10V 3V 34W TO-220FP
IPA60R160C6 INFINEON N Channel 23.8A 600V 0.14ohm 10V 3V 34W TO-220FP
IPA60R190C6 INFINEON N Channel 20.2A 600V 0.17ohm 10V 3V 34W TO-220FP
---------- Post added 17-04-12 at 00:04 ---------- Previous post was 16-04-12 at 23:31 ----------
also see this
FCP16N60N. FAIRCHILD SEMICONDUCTOR N Channel 16A 600V 0.17ohm 10V 2V 1.08W TO-220
FCP20N60. FAIRCHILD SEMICONDUCTOR N Channel 20A 600V 0.19ohm 10V 5V 208W TO-220
FCPF22N60NT FAIRCHILD SEMICONDUCTOR N Channel 22A 600V 0.14ohm 10V 3V 1.64W TO-220F
FDPF8N60ZUT FAIRCHILD SEMICONDUCTOR N Channel 6.5A 600V 1.15ohm 10V 5V 34.5W TO-220F
FQP5N60C FAIRCHILD SEMICONDUCTOR N Channel 4.5A 600V 2ohm 10V 4V 100W TO-220
IPA60R299CP INFINEON N Channel 11A 650V 0.299ohm 10V 3V 33W TO-220
IPA60R385CP INFINEON N Channel 9A 650V 0.385ohm 10V 3V 31W TO-220
IPA60R520CP INFINEON N Channel 6.8A 650V 0.52ohm 10V 3V 30W TO-220
IPA60R600CP INFINEON N Channel 6.1A 650V 0.6ohm 10V 3V 28W TO-220
IPA90R1K0C3 INFINEON N Channel 5.7A 900V 1ohm 10V 3V 32W TO-220
IPA90R1K2C3 INFINEON N Channel 5.1A 900V 1.2ohm 10V 3V 31W TO-220
IPA90R340C3 INFINEON N Channel 15A 900V 0.34ohm 10V 3V 35W TO-220
IPA90R500C3 INFINEON N Channel 11A 900V 0.5ohm 10V 3V 34W TO-220
IPA90R800C3 INFINEON N Channel 6.9A 900V 0.8ohm 10V 3V 33W TO-220
IPP50R140CP INFINEON N Channel 23A 550V 0.14ohm 10V 3V 192W TO-220
IPP50R199CP INFINEON N Channel 17A 550V 0.199ohm 10V 3V 139W TO-220
IPP50R299CP INFINEON N Channel 12A 550V 0.299ohm 10V 3V 104W TO-220
IPP50R350CP INFINEON N Channel 10A 550V 0.35ohm 10V 3V 89W TO-220
IPP50R399CP INFINEON N Channel 9A 560V 0.399ohm 10V 3V 83W TO-220
IPP50R520CP INFINEON N Channel 7.1A 550V 0.52ohm 10V 3V 66W TO-220
IPP60R099CP INFINEON N Channel 31A 650V 0.099ohm 10V 3V 255W TO-220
IPP60R099CPA INFINEON N Channel 31A 600V 0.099ohm 10V 3V 255W TO-220
IPP60R125CP INFINEON N Channel 25A 650V 0.125ohm 10V 3V 208W TO-220
IPP60R160C6 INFINEON N Channel 23.8A 600V 0.14ohm 10V 3V 176W TO-220
IPP60R165CP INFINEON N Channel 21A 650V 0.165ohm 10V 3V 192W TO-220
IPP60R190C6 INFINEON N Channel 20.2A 600V 0.17ohm 10V 3V 151W TO-220
IPP60R199CP INFINEON N Channel 16A 650V 0.199ohm 10V 3V 139W TO-220
IPP60R250CP INFINEON N Channel 12A 650V 0.25ohm 10V 3V 104W TO-220
IPP60R280C6 INFINEON N Channel 13.8A 600V 0.25ohm 10V 3V 104W TO-220
IPP60R299CP INFINEON MOSFET, N, TO-220 Channel 11A 650V
IPP60R380C6 INFINEON N Channel 10.6A 600V 0.34ohm 10V 3V 83W TO-220
IPP60R385CP INFINEON N Channel 9A 650V 0.385ohm 10V 3V 83W TO-220
IPP60R520CP INFINEON N Channel 6.8A 650V 0.52ohm 10V 3V 66W TO-220
IPP60R950C6 INFINEON N Channel 4.4A 600V 0.86ohm 10V 3V 37W TO-220
IPP90R1K0C3 INFINEON N Channel 5.7A 900V 1ohm 10V 3V 89W TO-220
IPP90R1K2C3 INFINEON N Channel 5.1A 900V 1.2ohm 10V 3V 83W TO-220
IPP90R340C3 INFINEON N Channel 15A 900V 0.34ohm 10V 3V 208W TO-220
IPP90R500C3 INFINEON N Channel 11A 900V 0.5ohm 10V 3V 156W TO-220
IPP90R800C3 INFINEON N Channel 6.9A 900V 0.8ohm 10V 3V 104W TO-220
IPW50R199CP INFINEON N Channel 17A 550V 0.199ohm 10V 3V 139W TO-247
IPW50R250CP INFINEON N Channel 13A 550V 0.25ohm 10V 3V 114W TO-247
IPW50R299CP INFINEON N Channel 12A 550V 0.299ohm 10V 3V 104W TO-247
IPW50R350CP INFINEON N Channel 10A 550V 0.35ohm 10V 3V 89W TO-247
IPW50R399CP INFINEON N Channel 9A 560V 0.399ohm 10V 3V 83W TO-247
IPW60R041C6 INFINEON N Channel 77.5A 600V 0.037ohm 10V 3V 481W TO-247
IPW60R045CP INFINEON N Channel 60A 650V 0.045ohm 10V 3V 431W TO-247
IPW60R045CS INFINEON N Channel 60A 600V 0.04ohm 10V 3V 431W TO-247
IPW60R070C6 INFINEON N Channel 53A 600V 0.063ohm 10V 3V 391W TO-247
IPW60R075CP INFINEON N Channel 39A 650V 0.075ohm 10V 3V 313W TO-247
IPW60R099CP INFINEON N Channel 31A 600V 0.099ohm 10V 3V 255W TO-247
IPW60R125C6 INFINEON N Channel 30A 600V 0.11ohm 10V 3V 219W TO-247
IPW60R160C6 INFINEON N Channel 23.8A 600V 0.14ohm 10V 3V 176W TO-247
IPW60R165CP INFINEON N Channel 21A 600V 0.165ohm 10V 3V 192W TO-247
IPW60R190C6 INFINEON N Channel 20.2A 600V 0.17ohm 10V 3V 151W TO-247
IPW60R199CP INFINEON N Channel 16A 600V 0.199ohm 10V 3V 139W TO-247
IRFB9N60APBF VISHAY SILICONIX N Channel 9.2A 600V 0.75ohm 10V 4V 170W TO-220
IRFB9N65APBF VISHAY SILICONIX N Channel 8.5A 650V 0.93ohm 10V 4V 167W TO-220
IRFBC20PBF VISHAY SILICONIX N Channel 2.2A 600V 4.4ohm 10V 4V 50W TO-220
IRFBC30PBF VISHAY SILICONIX N CHANNEL MOSFET, 600V, 3.6A TO-220
IRFPG40PBF VISHAY SILICONIX N Channel 4.3A 1kV 3.5ohm 10V 4V 150W TO-247
NDF02N60ZG ON SEMICONDUCTOR N Channel 2.4A 600V 4ohm 10V – 24W TO-220FP
NDF03N60ZG ON SEMICONDUCTOR N Channel 3A 600V 3.3ohm 10V – 25W TO-220FP
NTE2387 NTE ELECTRONICS N Channel 4A 800V 3ohm 10V 3V 125W TO-220
NTE2399 NTE ELECTRONICS N Channel 3.1A 1kV 0.5ohm 10V 4V 125W TO-220
NTE2974 NTE ELECTRONICS N Channel 6A 600V 1.1ohm 10V – 35W TO-220
NTE2989 NTE ELECTRONICS N Channel 10A 600V 1ohm 10V 4V 50W TO-220
SIHP18N50C-E3. VISHAY SILICONIX N Channel 18A 560V 0.225ohm 10V 5V 223W TO-220
STP11NM60 STMICROELECTRONICS N Channel 11A 650V 0.45ohm 10V 4V 160W TO-220
STP4NK80Z. STMICROELECTRONIC N Channel 3A 800V 3ohm 10V 3.75V 80W TO-220
STW43NM60N STMICROELECTRONICS N Channel 17.5A 600V 0.075ohm 10V 3V 255W TO-247
STW45NM50 STMICROELECTRONICS N Channel 45A 550V 0.1ohm 10V 4V 417W TO-247
STW55NM60N STMICROELECTRONICS N Channel 25.5A 600V 0.047ohm 10V 3V 350W TO-247
STW5NK100Z STMICROELECTRONICS N Channel 3.5A 1kV 3.7ohm 10V 3.75V 125W TO-247
STW7NK90Z STMICROELECTRONICS N Channel 2.9A 900V 1.56ohm 10V 3.75V 140W TO-247
STW8NK80Z STMICROELECTRONICS N Channel 6.2A 800V 1.5ohm 10V 3.75V 140W TO-247
STW9NK70Z STMICROELECTRONICS N Channel 7.5A 700V 1.2ohm 10V 3.75V 156W TO-247
TK12E60U TOSHIBA N Channel 12A 600V 0.4ohm 10V – 144W TO-220
TK15D60U(Q) TOSHIBA N Channel 15A 600V 0.24ohm 10V – 170W TO-220
TK15E60U TOSHIBA N Channel 15A 600V 0.3ohm 10V – 170W TO-220
TK20A60T(Q) TOSHIBA N Channel 20A 600V 0.19ohm 10V 5V 45W TO-220SIS
TK20D60U(Q) TOSHIBA N Channel 20A 600V 0.165ohm 10V – 190W TO-220
TK20E60U TOSHIBA N Channel 20A 600V 0.19ohm 10V – 190W TO-220
TK4A60D TOSHIBA N Channel 4A 600V 1.4ohm 10V – 35W TO-220
TK4A60DA TOSHIBA N Channel 3.5A 600V 1.7ohm 10V – 35W TO-220
Thank you mister_rf,
That is a huge list. :)
It would take me hours to compile the list into excel selection sheet.
I hope they are available in India.
Mister_rf
Thanks again. Is it possible to share the source of the above list.
Here I attach the above list in excel for the members here. using excel it easy to set filter and find the required component.
Dont forget to thank mister.
  • Mosfets.zip
Hello,
I tried to find the Mosfets given by mister_rf, but they are not available here in India. Tried many shops but they say "NO"
I would request if some Indian member who can help me out with the mosfet list that would be available in India..
