wideband 90° hybrid coupler
nashat1985
Newbie level 5
Newbie level 5
Hello friends
I am searching for a wideband 90° hybrid coupler with a frequency range, of 500 kHz- 250 MHz. Do you have any idea where I can find it? I plan to use it in Single-Sided Upconversion
Thank you in advance ...
PlanarMetamaterials
Edmonton, Canada
Are you sure a hybrid coupler is what you want? 500 kHz is an awfully low frequency for that type of technology. Probably an active phase shifter might be more along the lines of what I would expect to use.
nashat1985
Newbie level 5
Newbie level 5
Dear friend,
Thank you for your comment,
Can you please suggest phase shifter work at with the desired bandwidth…
BigBoss
Advanced Member level 6
Türkiye
-Bandwidth is too large for Hybrid Couplers
-Lower Frequency is too low for them.
-If you need a 90o for a single frequency( or a narrow bandwidth), there is solution.
**Multiple Cascaded Poly-phase filter can be a solution
**Frequency Divider can also be solution for 2xfosc
biff44
New England, USA
best i can do:
--- Updated ---
are these large signals, without much modulation?
you can drive a port of one mixer with the signal, and have a tracking PLL/VCO with a 90 degree phase shift drive the other mixer's port. An analog phase detector has a natural 90 degrees phase shift to it (works in quadrature)
    tony_lth
