I can see how low-IF could work by biasing the IF at half the channel bandwidth or greater. But in order to prevent adjacent channels from aliasing/imaging in, you'd need larger channel separation which is a pretty big deal.Well, if you have an rf carrier, say 1000 MHz with fm deviaton +/- 20 KHz, and you downconvert it to zero center freuqency, the "IF" output will consist of negative frequencies and positive frequencies. Most FM demodulators can not tell the difference between negative and positive frequencies, so the demodulator stops working. it would see 20 KHz and then 20 KHz and not see a change.
Zero IF can be done, it is just more complicated.
One approach is to do zero IF for some modulations, and "Low IF" for FM.
