Why working with op-amps is so popular ?
u04f061
op-amps are analogue devices.modern world is known to be digitally oriented.
still op amps are very famous.does this mean that there is a need for analogue circuitry for modern world.
Re: working with op-amps
See You can't differentiate a design As purely anlaog or purely digital. Any successful design consists of both these components. Analog and digital design are like faces of a coin.
Remeber that the real world is analog -- so when you have to interact with real, physical things you have to have at least some analog. Look at sensor and signal conditioning electronics -- they have to have some analog before then enter into the A/D converter. Power conversion is analog -- it might be controlled by some digital circuits -- but the main power section is made up of FETs and diodes with inductors and capacitors for filtering
Realworld is analog ....so ceratinly we need op-amp
Added after 5 minutes:
op-amp is mainpillar for analog computation
for ur knowledge at very deep submicron tech things are again changing to analog.
so analog can never die!
yes, opamp will for surely rule for a long long time, so far there is no its subsititute for it. also research and development ofr opamp never stop. so studying for opamp will be surely rewarding
op amp have replaced discrete amplifiers. but still they are appearing in literature an hardly used.what this means
hi dear,
i think that no body refuses the importance of op- amp. it smean taht a good circuit contains both the electrical as well as electronics components and it also depend on the requrement.
Especially in analog, OPamp does most of jobs..
Think about a feedback circuit!
analog is still important today
"THE WORLD IS ANALOGIC" is a so so answer, because the Modern Phisics demostrated that the nature is discrete, but in general the world is considerated analogic, for this reason, the analogic circuitery don´t disappear.
To certain extend, designing analog circuits is more difficult than designing digital ones. That's the reason why a analog designer is always more paid than a digital one.
Will
you got that right
Will
