Why we are using only D Flip-Flop in IC design?
prithivikumars
Member level 2
hi all,
Why we are using only D Flip-Flop in IC design. Why not all other Flip-Flops.
Prithivi.
roykyn
Full Member level 5
Re: D Flip-Flop
depends upon the IC design......like Toggle flip flops are used in frequency dividers....
or elaborate your question....
eternal_nan
Full Member level 3
eternity
D Flip-Flop
You can build most any flip flop using a D-flop and some gates.
kishore2k4
Full Member level 5
Middle Earth
Re: D Flip-Flop
In most of the complex digital designs, we need storage like registers, memory etc which can be build with D FF's, other FF's are also used but less often as the need arises.
anilkumarv
Member level 2
Re: D Flip-Flop
D flip flop is the basic flop. It can be used as memories (which is used in many applications). It can also be used as dividers by just adding a not gate. Moreover other flops are not easy to use/modify as D flip flop
akshay.raoy
Junior Member level 2
Re: D Flip-Flop
t ff is also used in frequency dividers....
dtn_me
Junior Member level 3
Re: D Flip-Flop
D Flipflop is completely scannable(Controllable & Testable).
prithivikumars
Member level 2
Re: D Flip-Flop
Hi all,
Thank you for your reply.
Prithivi.
sekapr
Re: D Flip-Flop
less area and less power consumption
sam536
Full Member level 5
Tokyo
Re: D Flip-Flop
D-FF will take less power consumption than any other flops.
T-FF is designed from D-FF with combo logic.
JF-FF is having 2 inputs to toggle. It will be difficult to design as well as controlling the switching activity ..
and more advantages. Please read John knight Digitial slides from Carleton University..
Regards,
Sam
alam.tauqueer
Full Member level 2
D Flip-Flop
Design a circuit with d ff is easy and also in case of jk ff we required to handle 2 input which is difficult as weel as controlling of both input is also not easy in case of large design.
As sam said D ff also take less power.
