Why verilog is known as RTL language?
akrlot
Member level 3
verilog hdl
hi;
why verilog is called as RTL langage?
could you give links/ebooks about verilog.Thx
verilog hdl
When Verilog is used in RTL level then flip-flops (registers) are used. For this reason is called Register Transfer Level.
For ebooks have a look at the forum for Ebooks Upload/Download.
    akrlot
Re: verilog hdl
Not only verilog but also VHDL, if the code you write is based on Register Transfer Level, it is called RTL.
    akrlot
Re: verilog hdl
there are some books on verilog in the forum,u could search
    akrlot
Re: verilog hdl
yes, what adap mentioned is what we also called "synthesizable verilog code". at RTL level, logic change depends on the clock for synchronize design. there is another level called behavirol level, in this level you just describe how ur design may function, it doesn't have to be in logic and register level, hence it's not synthesizable code.
hope i help u.
regards,
smart
    akrlot
Re: verilog hdl
h**p://www.dientuftp.com/down/verilog
verilog hdl
verilog can be used for RTL description in front end design, besides, verilog can be for behavial description, extent to a good verifacation language via PLI, and many netlist can be in a verilog format.
Re: verilog hdl
Any code that is synthesizable is called RTL. means register transfer where the created code synthesize to registers and the flow of data through that registers
Re: verilog hdl
Check out verilog by samir palnitkar....i think ur doubts wil be cleared...u could search for it in this forum
Re: verilog hdl
all synthesizable HDL are called RTL . BOOKs u can search from forum ,net......
