Why using optoisolator? Need sample of interface
shereen15
Newbie level 3
Hello everybody,
My project is design IC Controller for three-phase inverter using FPGA and VHDL coding. Now Im asked to design an interface circuit using optoisolator. I want to know the reason why I've to use optoisolator? And can I have sample of interface circuit using optoisolator?
Thank you.
Best Regards,
Shereen
Re: Why using optoisolator?
shereen15 said:
Hello everybody,
Thank you.
Best Regards,
Shereen
Opto isolators are used to electrically isolate(no noise coupling) the 'input' and the 'processing' circuits .
For ur Ref..
https://en.wikipedia.org/wiki/Opto-isolator
Regards,
S
The electrical isolation also prevents high voltages being transfered to the controller in the case of one of the components failing.
