Register Log in
Why use PrimeTime when DC can do timing analysis..?
giggs11
Member level 3
Hi guys,
I'm in a bit of a confusion here. I'm able to perform timing analysis on Synopsys DC but there is PrimeTime which also does STA. How would PrimeTime be more advantageous than DC's timing analysis..?
Can someone point out the advantages and uses of Primetime...?
Thanks guys.
sarath51
Full Member level 2
Primet Time has some specialzed inbuillt algorithms for Meeting Timing Puposes. The timing which canot be met by DC can be met by the timingspecific engines associated with Prime time and more over PT as become Timing Sign Off by most Fabs.
eternal_nan
Full Member level 3
eternity
1. Primetime's STA engine is a lot faster
2. More accurate delay calculator since the tool is aimed at sign-off rather than timing driven optimization
3. Support for signal integrity problem analysis (if buy the primetime SI license)
2. Although pt_shell and dc_shell apear to support the same commands at
a first glance primetime actually has many features and commands for timing
analysis that DC does not. For example, on chip variation analysis, interface-logic-models, several other types of timing models, advanced reporting capabilities.
There are probably many more reasons...
spauls
Advanced Member level 2
PT algo are faster than DC,
also DC cant do STA well.
sxqzj
Member level 4
I think its more accurate and faster to use PT than DC's timing analyis tool
visualart
Advanced Member level 1
Becasuse the Simulator can't simulate alll the path, and simulate need too many clock cycle
giggs11
Member level 3
hi guys,
Sarath, you said:
"Prime Time has some specialzed inbuillt algorithms for Meeting Timing Puposes. The timing which canot be met by DC can be met by the timingspecific engines associated with Prime time and more over PT as become Timing Sign Off by most Fabs."
Can PrimeTime be used to do further synthesis to meet timing constraints. Or do you mean that PT can simulate more paths of the design and for different timing analysises compared to DC...?
Thanks.
Thomson
Full Member level 3
It can caculate the timing using the information obtained from the P&R stage, which contains the capacitance and resistance so that the timing dealing process is conducted by the same timing engine. How can you assure yourself that the timing results from different engines are compatible and which one is more accurate? The PT has a sign-off accuracy.
xworld2008
Full Member level 4
The timing arc coverage , i think is different. In buildgate i have see a command "report_analyse_coverage" , which will report the timing arc coverage at synthesis.I don't know if DC have the same command. If DC have the command, you can try compare DC and PT timing analyse coverage may different.
qslazio
Full Member level 3
Prime Time is a standard for nowdays industrial design timing closure.
xworld2008
Full Member level 4
When i use Buildgate , I have see the timing coverage of BuildGate : check setup 86% , check holdup 61%, in my porject.
cklin
Newbie level 5
PT is more powerful than DC,such as case analysis or SI analysis. Meanwhile, PT
is faster than DC.
Toggle Sidebar
