Why use 0 Ohm Resistor
Most of then are for EMI, impedance matching and function debug!
hi all;
0 ohm resistors is also sometimes used as fuse , it depends on size of the resistor :1/8 W , 1/4W or ...
but ususally it is used where the fuse shouldn't burn easially
[/img]
On the old 8700 Motorola mobile phone there are two resistors on a ground plane, see picture; probably used during layout to connect different grounds on the schematic diagram.
Mandi
cube007 said:
Hello,
If you have a system with analogue and digital GND which have different names (AGND/DGND) in the schematic you can use 0 ohm resistors for connection analogue and digital GND.
Bye,
cube007
i think a better way in such cirsustance is to use a inductor rather than a 0 resistor.
In fact, 0 resistor is used as a jumper in most designs.
hi :
In high speed design, o resistor can minish 'stub' effect when it beening used as a switch.
